DC header on b16
Old May 22, 2002 | 08:32 PM
hybridbmw's Avatar
Default DC header on b16
I have redently purchased a DC ceramic coated 4-1 header. I got it off of a friend that wrecked his b16 del sol and he gave me a really good price on it. However, i have heard of clearance issues with the front cross member and something about an extra o2 sensor? Can anyone help me out with this? A link to a website or something would be great!
I had one more question. I remember seeing online a Flash calculator that would give you the compression and HP of a hybrid honda simply by dragging different heads, blocks, etc. Do any of guys in here have the link to it? Thanks!
Old May 22, 2002 | 08:49 PM
Redline130's Avatar
Default Re: DC header on b16 (speedaholic)
Depending on how your motor is mounted you may have to trim the front crossmember. Also, your B16 uses 2 O2 sensors so you will probably need to have another bung welded in. Or you could get your ecu re-programmed to only use one O2 sensor.
http://www.bojangz.com/calculator
[Modified by cyber13, 9:52 PM 5/22/2002]
Old May 22, 2002 | 08:57 PM
hybridbmw's Avatar
Default Re: DC header on b16 (cyber13)
Thanks alot for the help! Does anyone have a pic of where i need that extra bung welded in? Should i just bring it to a muffler shop or a machine shop? Thanks again for the help!
Old May 22, 2002 | 08:59 PM
hybridbmw's Avatar
One more thing, the website http://www.bojangz.com/calculator doesnt seem to be working. Is that the right address?
Old May 22, 2002 | 09:33 PM
Redline130's Avatar
My bad....now I remember, it moved but I don't remember the address.
Old May 22, 2002 | 10:32 PM
Stinkalope's Avatar
New User
Here you go http://www.bojangs.com/calculator/
miguel329
Apr 15, 2009 07:21 AM
4potnick
Feb 11, 2003 09:14 PM
JDMhondaslut2
Dec 11, 2002 11:53 PM
ef civic
Apr 29, 2002 04:43 AM
