200 whp all motor itr
Old Mar 11, 2007 | 06:06 PM
natedawg421's Avatar
Default 200 whp all motor itr
Hey everyone, this is probably my first post on your site. I have a del sol with a jdm itr. I was wondering if anyone thought it was possible to get 200 to the wheels before touching internals. I have the password jdm intake, stock jdm header, full 2.5 inch exhaust with no cat, chipped ecu, cam gears, competition clutch and lightened flywheel. I'm making 178 right now but my car wasn't heating up to temp. cuz I have a koyo radiator and it's probably overkill. So I have heating issues too I guess. Just wondering as a noobie to this site if anyone had any suggestions that could help me out. Thanks in advance... Nate
Old Mar 11, 2007 | 06:20 PM
richieTN's Avatar
Default Re: 200 whp all motor itr (natedawg421)
that sounds about right, for you to get 22hp without opening the engine will be hard. allthough you could get ITBs and skunk 2 stage 2's and that should be pretty close.
Old Mar 11, 2007 | 06:26 PM
00Red_SiR's Avatar
All Motor Mentor
The places I'd start would be to get rid of your intake and get an AEM 3" cold air or a comptech icebox system, they both outperform the one you are using. The stock header will have to go and you should consider an SMSP or Hytech, RMF header. Your exhaust is probably fine but you'll want to go with some better tuning like Hondata S200/Chrome etc as a chipped ecu with a generic program won't get you to far. You're going to need cams like Rocket Motorsport M22x's or Skunk Pro 1 cams as well to get to your power goals. Make sure you're running a stock thermostat, it should allow your engine to heat up properly and not over cool itself regardless of the radiator you're using.
I've personally seen a stock JDM ITR engine with Toda C cams, Hondata S200, Comptech Icebox, RC 310cc injectors, stock ITR cat back and DC JDM 4-1 header make 207 whp on a dynojet.
Old Mar 12, 2007 | 03:04 PM
I was going to lose my header in place of a Spoon header and go with an ARC airbox. Maybe the victor x intake maniflod for purposes later on with internals. My computer was chipped with chrome but I am interested in Hondata cuz a car isn't anything without a good tune the only problem is finding someone good. ITB's used to be at the top of my list of things to do but I can't find anyone to tune them in PA(at least on the west side). Would a fuel pressure regulator or bigger injectors help me at this point or is that something more beneficial with greater horsepower than I am wanting?
Old Mar 12, 2007 | 03:10 PM
MikeSarr_GSR's Avatar
Default Re: (natedawg421)
178 is good power for stock. Id say thats even a bit high, but if its there kudos to you. with pro1s, valvetrain, portmatched tb, 270-310s, a nice tri-y 2.5" header,
cat and exhaust, proper cam setup and tuning the ecu you should see a great
increase. expecting 200 is less than realistic but you can get there with the
right approach. if you say you are making 178, it might be good to show it
there are tuners here that might comment if they could see an a/f ratio and
a tq curve
Old Mar 12, 2007 | 03:22 PM
nice, thanks for the info. I'll put it up tomorrow. I know i didn't get the best possible tune I could get, but Like I said I have minor heating issues as well. thanks again though
Old Mar 12, 2007 | 04:49 PM
92TypeR's Avatar
FSAE
I'll break it down for you real easy.
DTR/SSR Header
Import Builders IM & some sort of 68mm TB
Rocket M22X or Skunk2 Pro-1
Well tuned, will make 200whp, no doubt in my mind.
Old Mar 12, 2007 | 05:37 PM
doood's Avatar
been there done that
Default Re: (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">I'll break it down for you real easy.
DTR/SSR Header
Well tuned, will make 200whp, no doubt in my mind.</TD></TR></TABLE>
post that dyno chart of the b18c5 with rm m22x's breaking 200whp
Old Mar 12, 2007 | 05:55 PM
92TypeR's Avatar
FSAE
Default Re: (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">post that dyno chart of the b18c5 with rm m22x's breaking 200whp </TD></TR></TABLE>
Ask and you shall receive
Old Mar 12, 2007 | 06:06 PM
doood's Avatar
that's the one
Old Mar 12, 2007 | 08:05 PM
4ornia's Avatar
Default Re: (doood)
well all your going to get is peoples opinions on what they like better.
i ve seen prolly over 80 dyno pulls with all diff types of honda setups.
you can reach that goal with a number of setups
the above listed were good most over kill though
valve train cams skunk 2s make good power on itrs i have one in my ej1
maybe run a thinner head gasket and some cam gears
decent header the jdm (style) dc 4-1 with a 2.5 collector works good for the money
other headers that out performed it did so by 3 -4 hp tops.
then its all in the tunning really i ve heard of people getting there car tunned by one guy and take it to another a week later and the next guy pulls alot more out of it.
tunning is really key. my .02
Old Mar 12, 2007 | 08:19 PM
92TypeR's Avatar
FSAE
Default Re: (4ornia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4ornia &raquo;</TD></TR><TR><TD CLASS="quote">decent header the jdm (style) dc 4-1 with a 2.5 collector works good for the money
other headers that out performed it did so by 3 -4 hp tops.</TD></TR></TABLE>
We dyno'ed a DTR B-unit header versus a DC JDM 4-1 on a 11.1:1 cr 1.8L and gained 12whp peak and 5-8ft-lbs of tq in the midrange. Same car, same day.
Old Mar 12, 2007 | 08:54 PM
smileycvc's Avatar
Intec Racing FTW once again producing a good motor. I just purchased an Import builders IM and Thottle body.
Old Mar 12, 2007 | 09:09 PM
milano sir-g's Avatar
victorx mani is junk for n/a set ups. tri-y, intake mani, m22/bc4/jun3/similar cams, tune, and your there.
Old Mar 12, 2007 | 10:00 PM
92TypeR's Avatar
FSAE
Default Re: (Milano SiR-G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Milano SiR-G &raquo;</TD></TR><TR><TD CLASS="quote">victorx mani is junk for n/a set ups. tri-y, intake mani, m22/bc4/jun3/similar cams, tune, and your there.</TD></TR></TABLE>
Do you even know what "tri-y" means?
As for the VictorX being junk for N/A...it is the only IM we've used that has broken 250whp on a DynoJet, so appearantly it isn't all that bad, especially since it beats every set of ITB's we've tested.
Old Mar 12, 2007 | 10:03 PM
JadeGreenEF9's Avatar
hahaha^^^ n00b got pwnt
Old Mar 12, 2007 | 11:53 PM
b16nonoy's Avatar
the itr head has a mild port & polish on the head...you can get the head done more. get some skunk2 cams and some dual valve springs & posibly better retainers.
and tuned...you should make some closer numbers...the cams would make the biggest difference..
jahraul
Sep 13, 2011 05:38 PM
lilo_goki
May 22, 2009 11:19 AM
HiChanDC2R
Aug 17, 2005 05:14 AM
digital sol
10
Nov 10, 2004 05:23 PM
soofisahab
Dec 14, 2003 09:57 AM
