Trouble removing front strutbar mount
Hey guys newbie here!
One of my mounting bolts for the front strut has been sheared off, probably from over torquing. I did a search on the forum and the most common way seems to be to bash it from the top till the welds holding the head breaks off.
I tried it but found the welds to be too strong to break off, in fact the plate its welded to started to bend.
The plate had bent quite a bit more (probably a 10mm clearance), but I tried to drive a wedge between the head and the plate to loosen up the weld before ultimately giving up
Anyone have any ideas? Remember it's pretty cramped under there also...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">hit it with a grinder</TD></TR></TABLE>
that seems like it would be a bitch to do in such a tight place...hmmm
haha to tell u the truth i never seen anyone try to take that piece apart yet
why would u? i am guessing you stripped the thread on one of the bolts there?
all you have to do to remove that tacked on stud is to hit it from the top with a punch and a 3-5lb sledge hammer.
Mine snapped off brilliantly in an unrelated encounter with a pothole the size of a crater (alignment etc went ALL wack after falling in) and I found the stud mysteriously snapped afterwards...
Position the punch carefully and hit it hard.
. o 69 o .
May 4, 2003 09:12 AM
