Did a search but can't find horn wire...1995 Accord 4Cyl LX 5spd
Old Mar 11, 2007 | 05:45 PM
compint's Avatar
Default Did a search but can't find horn wire...1995 Accord 4Cyl LX 5spd
Traced the harness coming from the steering column to the blue connector above the drivers left knee (that's where I was told it would be). Don't see a Lt/Green or Blue/Red wire though. In this harness, I see:
Red
Green
Blue
Green/yellow
Green/red
Red/green
Black
Am I looking in the right place?
Old Mar 11, 2007 | 07:14 PM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Did a search but can't find horn wire...1995 Accord 4Cyl LX 5spd (compint)
Are you looking for the horn relay? Or just looking for those two wires?
If you are just looking for those two wires, you could locate the horn relay (located on the left side of the center console under the dashboard, somewhat near the gas pedal, hard to tell in the manuals diagrams) which will have the LT GRN/BLU and BLU/RED wires as well as WHT/YEL and BLK wires, 4 wires tota. From there you should be able to trace the wires for whatever your trying to do.
Old Mar 11, 2007 | 08:25 PM
compint's Avatar
Default Re: Did a search but can't find horn wire...1995 Accord 4Cyl LX 5spd (TouringAccord)
Sorry, I am installing an alarm and was looking for the horn wire to connect to it.
Thanks
Old Mar 12, 2007 | 03:01 AM
H-T Order of Merit
ah, ok. well, if you find the horn relay (sorry if my description is a bit hard to follow) the BLU/RED wire goes to the horns and the LT GRN/BLU wire is coming from the horn switch. So find the relay and you should be good to go
Old Mar 12, 2007 | 07:30 PM
compint's Avatar
OK, can't find the horn wire. One question though. Do I need the horn connected? The alarm has a the siren. Is the horn honking really necessary also?
Thanks
Old Mar 13, 2007 | 04:27 AM
H-T Order of Merit
I would assume not but I'm no expert in install alarms.
89SiZero
Jul 1, 2014 09:02 PM
existanzcivicb20
Audio / Security / Video
Feb 6, 2014 09:31 AM
spurfan15
Oct 20, 2013 09:41 AM
senpai
18
Oct 16, 2004 06:55 AM
