Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Fog Light issues !
Old Mar 11, 2007 | 05:13 PM
WILD_WILL's Avatar
Default Fog Light issues !
I washed my car today so after i am done i notice some moister buildup on both fog lights arent these fog lights supposed to be waterproof. There were installed when i bought the SI so its def under warranty plus 1 of my 2500k yellow bulbs blew out because of this. I guess i should bring it in try to get new 1's has anyone else experience this BS with OEM fogs ?
Old Mar 11, 2007 | 05:22 PM
Type X's Avatar
Default Re: Fog Light issues ! (WILD_WILL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WILD_WILL &raquo;</TD></TR><TR><TD CLASS="quote">I washed my car today so after i am done i notice some moister buildup on both fog lights arent these fog lights supposed to be waterproof. There were installed when i bought the SI so its def under warranty plus 1 of my 2500k yellow bulbs blew out because of this. I guess i should bring it in try to get new 1's has anyone else experience this BS with OEM fogs ? </TD></TR></TABLE>
"You probably didn't seal it correctly when installing the bulbs....which are not Honda Recommended. Sorry but there is nothing we can do" - Bay Ridge Honda
Old Mar 11, 2007 | 05:38 PM
WILD_WILL's Avatar
Default Re: Fog Light issues ! (Type X)
? Did you post that on there website or something ive washed the car many times after the install and this never happened they were both fully tightened and water should not reach behind the fog light casing. I will put the stock bulbs back in and hope this dosent happen again it makes no sense to me how 1 day the fogs just happen to allow water to get inside the casing after many washes oh well i will try to justify this.
Old Mar 11, 2007 | 07:16 PM
originalg00kster's Avatar
honda wont do anything if you put those yellow bulbs in. if you would of kept the white bulbs...there would of been no moisture build up.
Old Mar 11, 2007 | 10:14 PM
xmx250's Avatar
Default Re: Fog Light issues ! (originalg00kster)
Try throwing the stock bulbs back in and take it to them. If they cant find anything wrong, then maybe its the seals on those JDM yellows. Maybe you might have to get new bulbs?
civicsracer
Oct 31, 2011 06:38 AM
redline870
45
Oct 12, 2008 01:23 PM
tavito18
Oct 2, 2008 01:38 PM
hamadiscool
Oct 2, 2006 07:14 PM
SIReg9
Dec 11, 2002 05:02 PM
