Endlink Noise (Function7)
I just installed my Function7 Heim-type endlinks on my 98 Coupe and was just wondering if a small amount of rattling is expected? It's nothing terrible and it's not frequent.. just when i hit smaller bumps (sounds like change jingling).
Everything is tight and i installed lock washers between the joints and the space left on the bolt.
Again.. I'm not really bothered by it but i'm just wondering if there's a rattle that comes a long with these type of endlinks? Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TanCar »</TD></TR><TR><TD CLASS="quote">checked change drawer?
ha-ha..
but really folks.. any help?
</TD></TR></TABLE>ha-ha..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by na+b18c_hatch »</TD></TR><TR><TD CLASS="quote">did you double check your work to make sure everything is torqued? sounds like there could be a bolt loose somewhere. </TD></TR></TABLE>
yeah i've been over everything 3 times now and greased up a few key spots.
It's not a constant sound.. just happens when i'm at low speeds
Car feels very very solid too
you have to tighten up the suspension when it is compressed. i cant think of the proper wording but when i did my comptech rear sway, i had to put it all together, lower the car to the ground, then tighten it up.
damn i cant think of what thats called.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol »</TD></TR><TR><TD CLASS="quote">you have to tighten up the suspension when it is compressed. i cant think of the proper wording but when i did my comptech rear sway, i had to put it all together, lower the car to the ground, then tighten it up.
damn i cant think of what thats called.</TD></TR></TABLE>
that's how i always tighten stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">mine did the same exact thing
I think ive mentioned it before, but I installed nylon washers where the joints were loose and that took care of it</TD></TR></TABLE>
word.. i just looked at my last thread
I have zinc plated lock washers in there.. i'ma go get some nylon ones tomorrow. Thanks again P-dig
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestSiR »</TD></TR><TR><TD CLASS="quote">word.. i just looked at my last thread
hopfully that works, let us know if it'll do anything
</TD></TR></TABLE>hopfully that works, let us know if it'll do anything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">hopfully that works, let us know if it'll do anything</TD></TR></TABLE>
i'll def post back with the outcome
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heretic:Si »</TD></TR><TR><TD CLASS="quote">mine were really noisy thats why i got rid of them. very annoying noise.
thanks again for those endlinks, fit perfect
I've heard of "other than stock" endlinks making noise.. i actually figured it would be worse. I just want to make sure the endlinks aren't broken.
Glad the oem's worked out for you
</TD></TR></TABLE>I've heard of "other than stock" endlinks making noise.. i actually figured it would be worse. I just want to make sure the endlinks aren't broken.
That sound is the whole end-link freely rotating around the bearings and taping against the washers. The metal-to-metal sounds like change jingling. Nylon washers give you metal tapping against nylon which makes almost no noise at all...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">That sound is the whole end-link freely rotating around the bearings and taping against the washers. The metal-to-metal sounds like change jingling. Nylon washers give you metal tapping against nylon which makes almost no noise at all...
word!
</TD></TR></TABLE>word!
pe-load
pe-load
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 »</TD></TR><TR><TD CLASS="quote">
pe-load</TD></TR></TABLE>
Think you meant pre-load...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takymoto »</TD></TR><TR><TD CLASS="quote"> **WAIT HOLD EVERYTHING**
Why would you want to remove your seam sealer?!?!?!?!?!?!?!?!!?</TD></TR></TABLE>
some one ban this guy
