BB/MC Swap?
Old Mar 11, 2007 | 03:36 PM
.Thomas's Avatar
Default BB/MC Swap?
The hard lines dont fit, what did i do wrong? if i loosen them on the prop valve will they fit in?
Old Mar 11, 2007 | 05:39 PM
Targa250R's Avatar
be professional
Default Re: BB/MC Swap? (TanCar)
Yeah, it would probably help if you mentioned what car you have and what master cylinder and booster you're swapping in
Old Mar 11, 2007 | 07:12 PM
.Thomas's Avatar
Default Re: BB/MC Swap? (Targa250R)
sorry. BB/MC ot of a 96 RS. 92 CX is the car.
Old Mar 11, 2007 | 07:54 PM
Targa250R's Avatar
be professional
What doesn't fit? Are both fittings the proper diameter? Does everything line up, but you just can't get the fitting threads started?
They take a bit of fiddling sometimes. Try lightly bending the lines over a long radius to get the angles just right.
Old Mar 11, 2007 | 07:56 PM
Luserkid's Avatar
I think the problem your running into is that you need to bend the lines a little. Although if its an ABS unit then its a totally different ball game.
eskerley
Mar 12, 2008 03:54 PM
IHateJDM
Aug 23, 2005 10:37 AM
t0eKnEe
10
May 26, 2004 05:25 PM
raene
Jul 31, 2003 01:37 PM
B19CivicHB
Nov 1, 2002 06:08 PM
