Rear disc conversion, E-Brake question....
Old Mar 11, 2007 | 03:03 PM
JDM_SOHC's Avatar
Default Rear disc conversion, E-Brake question....
Ok so my cables were to short on the gsr setup, so i ordered new ones for a civic... the rear passenger cable came but they cant order the rear left due to its out of stock... im gonna have to wait at least a week before i get the driver side cable, but question is... Would I be able to just install one cable for now, or do they only work when both installed... I noticed when i took off the handle and all that to get the dx ones out, that the spring lever on the end of the handle cant be pulled more or less from one side to the other so i didnt know if just 1 would work... can anyone clarify, thanks...
Old Mar 11, 2007 | 04:09 PM
JDM_SOHC's Avatar
Default Re: Rear disc conversion, E-Brake question.... (JDM_SOHC)
bump
Old Mar 11, 2007 | 05:30 PM
Targa250R's Avatar
be professional
You need both for it to work properly, because when you pull the lever with both cables attached, they balance each other's forces out. Otherwise, you'd be pulling the lever much farther for only 1 side to work - which I don't recommend, since disc e-brakes don't work nearly as well as drums.
Either wait until you get the part before you install the brakes, or just don't use the parking brake for a week . . .
Where did you order from? A Honda dealer should have the part within a couple of days now that the Honda parts distribution centers are doing daily stock order delivery.
Old Mar 12, 2007 | 03:46 PM
JDM_SOHC's Avatar
Default Re: Rear disc conversion, E-Brake question.... (Targa250R)
Yeah thats what i figured just because the way it looked like it worked i figured it wouldnt work with just one.
Old Mar 12, 2007 | 04:20 PM
MyEG6's Avatar
Just turn off the car while it is in gear. It'll keep the car from rolling. =P ghetto but it works.
Old Mar 12, 2007 | 04:25 PM
Cboi's Avatar
if u got the gsr setup wouldnt u need the gsr e-brake cable??? im thinking the civic cables will be too short still...
Bendito
Suspension & Brakes
23
Jul 6, 2012 10:30 AM
[713]
Apr 10, 2012 05:00 PM
rhdcivic05
Oct 1, 2006 12:26 PM
sirsmokesalot
Jul 16, 2006 11:18 AM
wesuri
Sep 7, 2005 01:14 AM
