valve spring??
Old Mar 11, 2007 | 10:36 AM
team 15's Avatar
Default valve spring??
Is there any way to take out the stock valve spring from my 97 civic ex when the head is still inside the block or you have to take out the cylinder head in order to take out the stock valve spring. I want to replace it w/ either crower valve spring or skunk 2 valve spring.
Old Mar 11, 2007 | 10:42 AM
JACER63's Avatar
Default Re: valve spring?? (team 15)
well you could use air. put motor on tdc and use a air to fill cly. like with a compression gauge adapter.my pops did this years ago on a 65 chevy impala to change springs.just go slow and take time. but something goes wrong youll end up taken head off anyways. gl
93SIRII
May 2, 2005 08:43 PM
99EletronblueSI
Nov 8, 2004 08:24 PM
importlegions
Jul 15, 2004 08:53 PM
Screamer
Dec 17, 2003 04:41 PM
