200+ WHP
Old Mar 11, 2007 | 08:37 AM
Type-r-driver-2000's Avatar
Default 200+ WHP
What will it take? I have my engine pulled and apart. Im about to order some **** and would like some direction. Im sure this was posted before so sorry if it was. So I you have over 200whp with out power adders, what do you have done? I have some ideas. So heres my plan. JDM ITR pistons, thin head gasket, skunk 2 manifold, jdm itr 4-1 header, valve springs, cams, injectors, fuel rail, ECT. I just dont wanna order a bunch of **** if I wont need it. let me know. I was also thinking of a turbo but I read alot of post saying to steer clear unless you have a lot of internals. Also my R is just a weekend driver, so i want it to be reliable
Old Mar 11, 2007 | 08:43 AM
Dave_B's Avatar
Well, I'm at 192 WHP and I "could" do more.
My mods are mugen head gasket, Mugen intake, SMSP header (1 piece) SMSP race exhaust (not recommended at all for your setup) and hondata S300 EMS. Tuned by LHT performance in Tampa. That's it.
If it weren't for rules, I would extrude hone the intake mani and go up to some JDM ITR pistons, or something very similar. In your case, you could do it without internal mods. But since your already there, a mild port and polish and some JDM pistons wouldn't hurt.
In any case, it can be done with quality parts without internal mods. If you there and want to anyway, or are rebuilding due to rings/wall conditions then I say go for it.
Old Mar 11, 2007 | 08:47 AM
RStoR's Avatar
Default Re: (Dave_B)
Read thru here. https://honda-tech.com/zerothread/1263436
Old Mar 11, 2007 | 08:52 AM
Tiger_Si's Avatar
where in Tampa LHT performance?
address?
thanks
Old Mar 11, 2007 | 08:55 AM
Dave_B's Avatar
Default Re: (Tiger_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tiger_Si &raquo;</TD></TR><TR><TD CLASS="quote">where in Tampa LHT performance?
address?
thanks
http://www.lhtperformance.net
John is the tuner there, awesome guy.
Old Mar 11, 2007 | 11:16 AM
redGSRguy's Avatar
Default Re: 200+ WHP (Type-r-driver-2000)
If you are going to get new pistons and your budget is big enough, you might want to look into forged pistons and rods for even more power . I know I should have, haha.
Old Mar 11, 2007 | 01:03 PM
92TypeR's Avatar
FSAE
Default Re: 200+ WHP (redGSRguy)
200whp isn't a hard task. You just have to select the right components that work well together.
I know I've posted this graph before...but very simple build with great parts that work well together:
Old Mar 11, 2007 | 01:15 PM
itrSteez's Avatar
Not to sound dumb, but where can you get M22's? I can't seem to find them anywhere.
I'm in the same boat you are though... I'm gonna put in JDM ITR pistons (25 over) and a thin headgasket, and some sort of header, either SMSP or Toda and hope that I can break the 200 mark.
Old Mar 11, 2007 | 01:20 PM
92TypeR's Avatar
FSAE
Default Re: (itrSteez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itrSteez &raquo;</TD></TR><TR><TD CLASS="quote">Not to sound dumb, but where can you get M22's? I can't seem to find them anywhere.</TD></TR></TABLE>
PM Clean Rice
Old Mar 11, 2007 | 01:22 PM
neo_'s Avatar
Camp1320 carries them too I believe.
Old Mar 11, 2007 | 01:31 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-r-driver-2000 &raquo;</TD></TR><TR><TD CLASS="quote">I was also thinking of a turbo but I read alot of post saying to steer clear unless you have a lot of internals. </TD></TR></TABLE>
200whp and turbo is piece of cake.. keep it around 275whp and it will be reliable and much less internals that you would need in a n/a build. forged pistons/rods is all you really need as far as non oem stuff goes inside the engine. i would recommend arp headstuds but thats all you need. no cam gears/camshafts/retainers.. everything you got inside itr is fine for that much hp except for pistons rods but some even go that far on stock internals
Old Mar 11, 2007 | 03:58 PM
Default Re: 200+ WHP (vtec.dc2)
I hear stories about turbos. I was thinking that then I read some posts no to go there. So you think forged pistons and rods would make it a reliable street car with a turbo? Im open for all ideas. I have ordered anything yet.
Old Mar 11, 2007 | 04:01 PM
cltitus's Avatar
dave how much did you pay for the smsp header?
Old Mar 11, 2007 | 04:04 PM
Dave_B's Avatar
Default Re: (cltitus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cltitus &raquo;</TD></TR><TR><TD CLASS="quote">dave how much did you pay for the smsp header?</TD></TR></TABLE>
I paid 1350 for the entire setup. IIRC $1200 of it was the header alone.
Dave now has other "newer" versions of this header. You may want to contact SMSP directly since they offer mild steel, stainless steel, 1 piece, 3 piece, coated. There are several various options you can go with.
HTH.
Old Mar 11, 2007 | 04:09 PM
cltitus's Avatar
yea i have been thinking go smsp or keep stock header/bc spec 3 exhaust.
Old Mar 12, 2007 | 08:35 AM
Is 11:1 high enough for Rm22xx cams
Old Mar 12, 2007 | 11:47 AM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-r-driver-2000 &raquo;</TD></TR><TR><TD CLASS="quote">Is 11:1 high enough for Rm22xx cams</TD></TR></TABLE>
Perfect.
Old Mar 12, 2007 | 12:27 PM
Teamdiesel's Avatar
I have noticed that with all the M22x dynos I have come across they do not produce that much torque. Is that just a situation where all the car did'nt have the rightpackage to bring out the cams potential, or is it just the expected output of the cam.
Old Mar 12, 2007 | 01:17 PM
gsrdelly's Avatar
itb
Old Mar 12, 2007 | 01:53 PM
hayabusa160's Avatar
Default Re: 200+ WHP (gsrdelly)
gsr motor ls crank and rods jdm itr pistions ported gsr head. skunk2 stage2s. aebs intake mani.
2 years ago i made 202 thats with the stock gsr intake manifold that was ported.
i made 210 last week. with the aebs intake manifold and prototype velocity stack.
Old Mar 12, 2007 | 02:55 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrdelly &raquo;</TD></TR><TR><TD CLASS="quote">itb</TD></TR></TABLE>
ok?
Old Mar 12, 2007 | 03:28 PM
CXtypeR's Avatar
i thought m22xx is too aggressive for 11:1 compression and m22x would be a better choice
Old Mar 12, 2007 | 04:36 PM
92TypeR's Avatar
FSAE
Default Re: 200+ WHP (CXtypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CXtypeR &raquo;</TD></TR><TR><TD CLASS="quote">i thought m22xx is too aggressive for 11:1 compression and m22x would be a better choice</TD></TR></TABLE>
IIRC, the only difference between the M22X and M22XX is one has a single large primary (X) and the other has two large primaries (XX) similar in design and profile to the Skunk2 Pro-1/2 cams. Dialing in idle is a little trickier, but you will see better midrange numbers, but identical VTEC lobes.
Old Mar 12, 2007 | 07:10 PM
gsr-2nr's Avatar
Default Re: 200+ WHP (92TypeR)
headwork,bore to 2.0, high comp pistons, metal headgasket, stage 2 or 3 cams, hondata.
Old Mar 13, 2007 | 08:06 AM
Default Re: 200+ WHP (gsr-2nr)
Thanks for all the replies. Ill keep ya posted on the build. A soon a my pal-pay is working I can get some parts. Hopefully the car will be done for april. Does anyone know a good tuner in Pittsburgh?
futrhondaownr
Oct 11, 2008 01:11 PM
esohsee
53
Apr 20, 2006 07:09 AM
fuck honda-tech
May 21, 2004 10:12 AM
jdm jedi
19
Mar 16, 2004 06:06 PM
Chris
Jul 1, 2002 07:13 PM
