b20
Old Mar 11, 2007 | 03:50 AM
hspoon's Avatar
Default b20
got a b20b in a eg coupe.. and i would like to know wat would be the proper ecu for it,,,, i used a pr4 and a p75 and it wont stay on... used a chipped p61 and it runs shitty...??
Old Mar 11, 2007 | 04:28 AM
B18CivicEH2's Avatar
Default Re: b20 (hspoon)
well...if you converted the motor to OBD1, then you need the OBD1 LS ECU (P75)...if you kept your motor OBD2, then you use the same OBD2 B20B ecu but just get a jumper harness which converts OBD1 to OBD2a or OBD2b, depending on what OBD2 your motor is..
Old Mar 11, 2007 | 09:36 AM
hspoon's Avatar
Default Re: b20 (B18CivicEH2)
b20 ecu... its automatic???
Old Mar 11, 2007 | 09:48 AM
Boostedb20EH2's Avatar
Why dont you run a p28
Old Mar 11, 2007 | 09:51 AM
hspoon's Avatar
Default Re: b20 (Boostedb20EH2)
do i need to chipped it for the b20?
Old Mar 11, 2007 | 10:10 AM
Well i was making the suggestion that you were getting it tuned. You would need a conversion harness....wait...how did you use a p61?
Old Mar 11, 2007 | 10:37 AM
envee's Avatar
hondata.
Old Mar 11, 2007 | 10:38 AM
hspoon's Avatar
my bad.. my car is a eg coupe.. p61 its obd1
Old Mar 11, 2007 | 11:01 PM
envee's Avatar
pick an ecu and put hondata on it and get it turned. problem solved.
Old Mar 11, 2007 | 11:12 PM
swells's Avatar
Default Re: b20 (envee)
You know Brent and Darren?
mackinit
Mar 4, 2011 12:20 PM
93redeghatch
Mar 24, 2010 11:43 AM
TheBigSPool
Engine Management and Tuning
Oct 1, 2009 09:23 PM
slo_ej8
Apr 8, 2008 04:34 AM
Aodhan
Nov 14, 2007 09:10 AM
