CYP sensor?
My "check engine" light came on yesterday and its giving me a code 9 which is the CYP sensor (i think thats right). Is there a way to fix that without replacing the whole distributor? Also will this code cause my car to skip. It wasnt skipping when the light first came on, but after a few hours it started and is still skipping.
you should really try searching....but i'll try to lead you to the right direction....hopefully this helps
https://honda-tech.com/zerothread?id=969598 CYP is coming on my ECU
https://honda-tech.com/zerothread?id=1031954 code 9 pt.1
https://honda-tech.com/zerothread?id=1073679 code 9 pt.2
start reading and good luck...
Jimster480
Dec 23, 2009 03:14 PM
Airbag Club
11
Mar 10, 2005 03:05 PM
