Which way does cam gear point on compression stroke...
Old Mar 10, 2007 | 05:06 PM
hondaless's Avatar
Default Which way does cam gear point on compression stroke...
Ok changed waterpump now the timing is off some how. When you have the crank TDC where does the camgear "UP" mark point??? Is it supposed to be on the bottom lined up with the crank? or is it supposed to be at the top???
Thanks
Old Mar 10, 2007 | 05:20 PM
Hybrid96EK's Avatar
Default Re: Which way does cam gear point on compression stroke... (hondaless)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaless &raquo;</TD></TR><TR><TD CLASS="quote">Ok changed waterpump now the timing is off some how. When you have the crank TDC where does the camgear "UP" mark point??? Is it supposed to be on the bottom lined up with the crank? or is it supposed to be at the top???
Thanks</TD></TR></TABLE>
Are you serious? Logic would tell me (even if I didn't know the answer) that it needs to point *UP*... So what do you think?
nemesis25
Dec 30, 2007 03:23 PM
Civicman86
Jun 22, 2006 10:01 AM
90si_mugen_crx
Jun 23, 2005 05:49 PM
HONDATUNER92
25
Jul 2, 2004 11:56 AM
Tommy_Gunns
Aug 23, 2002 03:07 PM
