where to find turbo for zc
Old May 22, 2002 | 05:48 PM
zc crx's Avatar
Default where to find turbo for zc
What the topic says.... I've heard of many people turboing their zc engines but I haven't found one site on the internet which sells turbos for it. I know of people using kits for other cars and modifying them, and making their own home made kits, but is there any site on the net which sells turbo kits specifically for zc engines in crx's?
Old May 22, 2002 | 05:59 PM
SC0TT's Avatar
Default Re: where to find turbo for zc (zc crx)
http://www.revhard.com Makes a kit for the D-series engine. Kinda spendy though.
Old May 22, 2002 | 06:37 PM
ivanED9's Avatar
Default Re: where to find turbo for zc (cr-tegra)
Check out the Greddy 92-95 Civic EX kit... needs only a little modification but the turbo size is very well matched to the ZC.
Old May 22, 2002 | 06:45 PM
Denny317's Avatar
Default Re: where to find turbo for zc (ivanED9)
Yeah, pretty much bolts up to the ZC, with literally very minor changes.
Old May 22, 2002 | 07:14 PM
zc crx's Avatar
Nice... what mods are needed? And is it pretty much the same price as the on listed on Greddy's site all over the internet?
Old May 22, 2002 | 07:17 PM
EP3_05's Avatar
You will have to bang and bend the front crossmember to clear the downpipe. The charge pipes will have to be modified to fit. The exhaust manifold will need to be modified at the corners so it will mate up to the head. You will also have to use an fmu setup, large injectors and pump, or standalone for fuel management because the injectors and bluebox that come with the kit will not work. Check out
http://www.optauto.com
They seem to have good prices on the kit.
[Modified by 91civic, 11:18 PM 5/22/2002]
Old May 22, 2002 | 08:01 PM
zc crx's Avatar
Also, are intercoolers the same way? Like, do intercoolers from 92-95 civic ex's work out with the zc motor? Thanks for all the input guys.
Old May 22, 2002 | 08:09 PM
EP3_05's Avatar
The intercooler will work fine. I believe the endtank openings are positioned correctly. If you want to be cheap go with a starion intercooler and have the endtanks modified.
Old May 22, 2002 | 08:14 PM
Bgladfelter's Avatar
Default Re: where to find turbo for zc (91civic)
turbocivic.net
1495 or so for the kit.
Group Buy Center, 1500 shipped.
Drag kit 2699 with Importparts 10% off.
Old May 22, 2002 | 08:33 PM
sampoerna's Avatar
Default Re: where to find turbo for zc (Bgladfelter)
check out this site
http://www.anyturbo.com/HONDATURBOS.HTM
and the ones below
frequency
Oct 31, 2007 12:22 PM
spuddo01
Feb 16, 2006 02:14 PM
flip1199
Jan 13, 2005 01:17 PM
noname11
Apr 13, 2003 04:43 PM
REDBARON
11
Dec 13, 2001 06:15 AM
