Help with B16 Swap removal
Old Mar 10, 2007 | 09:51 AM
JDM_EK_JOE's Avatar
Default Help with B16 Swap removal
hey guys Im having some problems removing my B16 Swap. My first problem is the mount on the transmission. There is a bolt directly under the bracket(frame) and I cant get @ it. I dont have a engine hoist and I need to get this off cause it'll get caught up with the mount bracket when i try to take it out. Also the bitchass shift linkage pin isnt coming out. I've tried everything, including a punch and still it isnt coming out. WTF. any recommendations? I dont wanna take the swap out from the bottom
Old Mar 10, 2007 | 10:09 AM
92civicfreak's Avatar
ok... u dont have an engine hoist & u dont want to take it out of the bottom... how stong are u?
Old Mar 10, 2007 | 10:26 AM
gibsanez's Avatar
Default Re: (92civicfreak)
it's possible with two people, and especially if you plan on replacing your rotted fender so you can rest the engine on that while you change carrying position .
First off, at least try and see if you have a buddy than can lend you a hoist.
As for the bitch pin, this was posted like 10 minutes after your thread
http://www.performanceforum.co....html
The punch should have worked, unless the one you're using is too big, but i'll give you more credit then that. Hope i helped.
Old Mar 10, 2007 | 02:35 PM
or u can just simply cut it out....
& if u cant borrow a hoist, go to autozone & buy one for like $150, they are cheap, but are GREAT!!!.... my brother baught one from there & it has already paied itself off
jdm4lif life
Oct 26, 2015 12:10 PM
killercrx91
Mar 13, 2009 04:08 PM
si90rex
Apr 28, 2006 12:21 PM
EF_generation
Oct 6, 2004 04:23 PM
theRiby
Apr 30, 2004 11:09 AM
