broken fog lights
2 days ago i installed some foglights in my integra, turned them on to test them and they worked great. turned them off and just let the car sit until the next day when i go and turn them on again and they do not work. the bulbs look fine the switch has a light turned on when in the on position and that turns on the fuse is fine and all the wiring is fine but the lights do not work. i looked at the fogs and when i saw a ground came off on just one of the bulbs i put it back in place and try again but they still do not work and all the grounds and power are connected properly. i dont understand what the problem could be...can anyone help me?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94 ls teg »</TD></TR><TR><TD CLASS="quote">check ur wires </TD></TR></TABLE>
all the wires are fine they didnt get touched like i said the car just sat...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectac »</TD></TR><TR><TD CLASS="quote">take the light bulb out and test for voltage with the switch on u should have 12 vdc.
if no dc volts check all wires over again.</TD></TR></TABLE>
the switch has a light in it when its in the on position so im assuming that there is power at the lights...but ill check it out thanks...
any other suggestions???
Canadian_EF
Apr 26, 2010 10:39 PM
