I just got my GSR but it has a few issues
First off when I switch where the air directs in the vents the lighting for the other buttons will turn off. Is this a common problem is there something I could look into? the car is completely stock except a ricy body kit and some altezza's that I replaced with stockers right away.
Also the passenger side seat it looks like on the front where the seat sit in the track theres a spring missing. the front right in the passenger seat clucks when you hit bumps get on the brakes u can clearly tell that its moving is there some way to fix it? will the seat come apart from the seat rail?
it also seems like the driver side window switch is going to go soon the switch is very loose
umm, I'm pretty sure when u push a new button for the air ducts, the lights are suppose to turn off, and the new one comes on telling u what button and air ducts are active.... About the seat, just take it out, 4 bolts to unbolt, then look underneath and see if anything's missing or needs some repairing.
Jason seems to somewhat of a smartass. At night when the backlighting is on, there is another light that lets you know which option you have picked. I lose all of my backlighting when I turn my blower on. That is what I was trying to say. This is what mine does....not sure if you have the same issue.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricer4now »</TD></TR><TR><TD CLASS="quote">First off when I switch where the air directs in the vents the lighting for the other buttons will turn off. Is this a common problem is there something I could look into? the car is completely stock except a ricy body kit and some altezza's that I replaced with stockers right away.
When you push a button for an accessory, only that accessories light should be on. For example, if i push the A/C button to turn on the A/C (which i hope we get to use soon, sick of this winter ****) the A/C buttons light should come on. No other lights should be on.
it also seems like the driver side window switch is going to go soon the switch is very loose</TD></TR></TABLE>
The seat wont come apart from the rail. Ive never really looked at the bottom of my tegs seat since i havent had a problem with it yet (keeping fingers crossed). Post up a pic if you can so we can help you out.
VTECorona
Sep 25, 2003 09:15 PM
