Few quick Questions
<U>just to let you know its a 93 hatchback so please to flame saying im in the wrong forum...</U>
Was wondering if a gsr header will fit on a ITR motor, and what years fit on a 97? also will 98 oem obd2 injectors work in a ITR 97 motor to pass smog? And will any intake from an integ work on the ITR motor/manifold?
sorry if their noob questions but i dont want to buy the wrong stuff to get it smog'd
The bolt pattern is the same, so yes.But i dont know how the exhaust lines up so im not fully sure,other than pretty much any b-series header will bolt onto any b-series engine.
so i basicly can use any year? or does it go 91 - 93 and 94 - 00?
also what years do the injectors need to be for a 97, can i use other years other then the 97 itr ones? from a gsr?
all b series headers will bolt to the head. but you'll probably have to do something about the cat flange. all b series injectors are the same provided they are the same obd.
so will a gsr header on a itr motor, stock LS intake, stock obd2 injectors pass smog. thats all i need to know, and if not, what do i need to change?
jdmekcivic2eg
Apr 23, 2002 06:22 AM
