Looking to get a 2002 RSX Type S
I have a person who wants to trade car, his is a stock Blue 2002 Type S with 75000 Miles on it, that more then my 2000 has on it, anyways, what should i look for when buying a used RSX any pointers would be great
also it's a trade + cash on his part, good deal? The KBB is 14100 for his car in good condition.
seeing that it is stock
just take it for a test drive and see how you like it
depending how good, it sounds like 14000 is a ok deal
you may find a better deal with simliar miles but it just come down to the overall condition
good luck
good luck
lets see... 3rd gear pop out is normal
nothing else i can really think of if the car is stock
humm...i'm sure someone else can answer this question better than me since i've only owned a 05 then a 06
good luck
good luck
1) inspect the car inside and out, look for dents/scratches.check the tires for treadlife.pop the hood and see if any aftermarket **** is on there, and see if its installed properly,and if its decent quality.when you open the hatch check for tape lines in the area where the hatch goes down when closed. this is a method to use when seeing if the car has previously been wrecked and repaired.
2)test drive it. make sure the car drives good and doesnt seem to lag , check all gears to make sure theyre all functionable. and yes 3rd gear pop out comes standard with the type-s haha no charge.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyK20Rips! »</TD></TR><TR><TD CLASS="quote">1) inspect the car inside and out, look for dents/scratches.check the tires for treadlife.pop the hood and see if any aftermarket **** is on there, and see if its installed properly,and if its decent quality.when you open the hatch check for tape lines in the area where the hatch goes down when closed. this is a method to use when seeing if the car has previously been wrecked and repaired.
2)test drive it. make sure the car drives good and doesnt seem to lag , check all gears to make sure theyre all functionable. and yes 3rd gear pop out comes standard with the type-s haha no charge. </TD></TR></TABLE>
lol lol lol
and wheel hop is a bonus
lol lol lol
tRex99
Apr 21, 2005 06:44 PM
integraautox
Nov 20, 2003 08:08 PM
