K20A3 swap in 97 civic...
ok, i've looked thru all the posts and do not believe i have seen any about a K20A3 swap into an 97 civic coupe. if there is one someone pls help me find it. if not, i need to know about what specifically i will need for this swap to work. the engine is coming out of a 03' civic sir. also should i be able to use the same size axle's from the 03' on my 97'. thanks and appreciate any help. S......
go to http://www.k20a.org much more information on the k series swaps. I personally would not go with the k20a3 but look around on k20a.org and see what everyone hasto say.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timaa66 »</TD></TR><TR><TD CLASS="quote">I personally would not go with the k20a3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spidersam »</TD></TR><TR><TD CLASS="quote">ok, i've looked thru all the posts........</TD></TR></TABLE>
all the posts eh?
all the posts eh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spidersam »</TD></TR><TR><TD CLASS="quote">ok, i've looked thru all the posts </TD></TR></TABLE>
LIAR!!!
I bet even if no one has done it in a 97 coupe on this website, someone has done it in a 96, 98, 99, and 00 coupe.
http://www.k20a.org FTW
LIAR!!!
k20a.org is a good site...but you can also find what you need in the Hybrid forum....try there too...i know theres a thread there for a K20a into a EG...im sure you can find what you need there..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timaa66 »</TD></TR><TR><TD CLASS="quote"> I personally would not go with the k20a3 but look around on k20a.org and see what everyone hasto say.
Measly as engine.I mean,its as good as a B16 stock but with a price tag 4 times higher
it still has potential, i belive someone made some cams for it and picked up about 15 whp or something like that from cams alone. it could probably be had for cheaper than a k20a as well, because they arent high in demand
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heylookits shawn »</TD></TR><TR><TD CLASS="quote">it still has potential, i belive someone made some cams for it and picked up about 15 whp or something like that from cams alone. it could probably be had for cheaper than a k20a as well, because they arent high in demand</TD></TR></TABLE>
if you want 160hp go with the K20A3,but then again how about you get a B16 for a lot cheaper and still have 160hp?
If youre going to spend money on a k20a3 to get something like 200hp how about you just get an K20A2 and do i/h/e?Cheaper and faster.
The only reason why you should get an A3 is if your car had a previous K engine in it and you blew it up or you got a really good deal on 1.
messiahcomplex
Aug 19, 2005 10:15 AM
