Not plugged cruise control nipple on the back of the intake manifold vacuum leak possible?
Hello!!! I was wondering if not plugging the cruise control nipple on the back of the intake manifold can cause a vacuum leak. Is it possible? Thanks.
well DUH.....
yeah you have a hole in your IM and you think it won't cause a leak??
hello captian obvious
If you want to plug it off, you can use a short piece of vacume hose and a golf tea. It is just basically a hole, small, but a hole into the intake. If you aren't using the cruise control, definitely plug it off. It should idle a lot better!
5exy_Ek
18
Oct 26, 2010 04:56 PM
MrRabbit87
Dec 10, 2008 09:38 AM
