Car wont accelerate at 0-50% throttle when warm only goes at 50%+ HELP!!! TPS??
Old Mar 9, 2007 | 12:44 PM
95BlkGSR's Avatar
Default Car wont accelerate at 0-50% throttle when warm only goes at 50%+ HELP!!! TPS??
i currently have a
1999 Ls JDM b18c swap Integra
stock p28
b18c bottom end
cp pistons
manley rods
b16 head
Supertech valves valves springs retainers
problem i am having is...
after the car warms up to normal opperateing temp. , when i hit the gas at about 50% throttle its like im at 0% throttle.
but if i got 75%+ on the throttle the car will go.
its like the motor isnt getting fuel or my throttle body doesnt open up unless i press the gas hard
and after its warm the car will try and idle at like 500-600rpms and normal is 800
but if i turn the car off and back on it will run fine for about 5 min. then continue to do the same thing
i got a new ecu
new engine wiring harness
had my TPS sensor recalibrated
do i need a new TPS
i have a feeling its a senor i just cant figure out which one...
any help would be greatly appreciated
i will try and get a video posted ASAP
my shop does not no the problem and i need to get motor tuned and i dont want to put it on the dyno while its doing this
Thanks.
Nick
Old Mar 10, 2007 | 07:36 PM
95BlkGSR's Avatar
Default Re: Car wont accelerate at 0-50% throttle when warm only goes at 50%+ HELP!!! TPS?? (95BlkGSR)
help any1?
Old Mar 10, 2007 | 07:51 PM
r3v da t3g's Avatar
Sorry if it doesnt answer your question but how do you recalibrate the TPS ?
Old Mar 10, 2007 | 08:11 PM
Blackturboteg's Avatar
Default Re: Car wont accelerate at 0-50% throttle when warm only goes at 50%+ HELP!!! TPS?? (r3v da t3g)
Is it a 5 speed ? if so every think the clutch went?
Old Mar 10, 2007 | 10:35 PM
95BlkGSR's Avatar
Default Re: Car wont accelerate at 0-50% throttle when warm only goes at 50%+ HELP!!! TPS?? (Blackturboteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackturboteg &raquo;</TD></TR><TR><TD CLASS="quote">Is it a 5 speed ? if so every think the clutch went?</TD></TR></TABLE>
its a brand new exedy stage 2
Old Mar 10, 2007 | 10:37 PM
95BlkGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r3v da t3g &raquo;</TD></TR><TR><TD CLASS="quote">Sorry if it doesnt answer your question but how do you recalibrate the TPS ?</TD></TR></TABLE>
took it to my tuning shop
im assuming it has the due with the amount of power running thrught normal is 4.5v
Old Mar 11, 2007 | 11:46 AM
95BlkGSR's Avatar
bump
Old Mar 11, 2007 | 02:52 PM
onesikdb8's Avatar
If the TPS has rivets on it, it never needs to be calibrated. It just needs to be replaced and then you have to calibrate it after that. You recalibrate it by back probing the TPS and reading the voltage at closed throttle with the ignition on. It should read near .5 volts, then you tighten the bolts, screws, or allens and test it at WOT and it should read near 4.5 volts. Of course if you have a SAFC or VAFC, you can just go to the sensor reading option and look at the voltage of the TPS there.
Old Mar 11, 2007 | 02:53 PM
onesikdb8's Avatar
Are you throwing any CEL's?
Check the flow of your fuel filter....it may be clogged.
Old Mar 11, 2007 | 03:10 PM
95BlkGSR's Avatar
Default Re: Car wont accelerate at 0-50% throttle when warm only goes at 50%+ HELP!!! TPS?? (onesikdb8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onesikdb8 &raquo;</TD></TR><TR><TD CLASS="quote">Are you throwing any CEL's?
Check the flow of your fuel filter....it may be clogged.</TD></TR></TABLE>
no codes at all ill check my fuel filter thanks man
open to any ideas
Old Mar 12, 2007 | 04:34 PM
trrbl1bmx's Avatar
Try unplugging your TPS, you will throw a code 7 but if your car runs fine you know it's your TPS. I'm have a TPS problem and can't get it working so I have been riding around with my TPS unplugged and the ECU is using the signals from the MAP sensor to calculate air flow and load.
Old Mar 13, 2007 | 01:00 PM
95BlkGSR's Avatar
Default Re: Car wont accelerate at 0-50% throttle when warm only goes at 50%+ HELP!!! TPS?? (p00n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p00n &raquo;</TD></TR><TR><TD CLASS="quote">Try unplugging your TPS, you will throw a code 7 but if your car runs fine you know it's your TPS. I'm have a TPS problem and can't get it working so I have been riding around with my TPS unplugged and the ECU is using the signals from the MAP sensor to calculate air flow and load.</TD></TR></TABLE>
aight good idea ill give that a try thanks man
Old Mar 13, 2007 | 09:05 PM
95BlkGSR's Avatar
ok so i unplugged the TPS sensor and it ran fine
i will be buying a new TPS tomorrow and im guess its going to work out fine
Old Mar 14, 2007 | 06:22 PM
95BlkGSR's Avatar
autozone doesnt carry it so im going to acura dealership next
Old Mar 21, 2007 | 11:41 PM
95BlkGSR's Avatar
well no one sells the TPS separate says it come with the throttle body
went to acura and autozone
so any ideas
just buy a new throttle body?
Old Mar 29, 2007 | 12:14 AM
7808's Avatar
cant you recalibate it ?
Old Apr 7, 2007 | 12:37 AM
95BlkGSR's Avatar
Default Re: Car wont accelerate at 0-50% throttle when warm only goes at 50%+ HELP!!! TPS?? (7808)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7808 &raquo;</TD></TR><TR><TD CLASS="quote">cant you recalibate it ? </TD></TR></TABLE>
already tried
Old Apr 7, 2007 | 06:23 AM
Dogginator's Avatar
Daisy... Daisy...
Buy a used TPS. Most Honda TPSs are interchangeable.
QuickshiftsProject
May 16, 2011 09:33 AM
jordan_civic
May 27, 2008 10:44 AM
AC2i0v0i0c
Oct 21, 2004 08:08 AM
mongoliandonuts
Sep 10, 2004 09:47 AM
itsJDMyo
May 30, 2004 04:05 AM
