CAN ANYONE HELP ME !!!!
CPS is not working or wired up incorrectly. You've been told this in two threads. Why do you need to make a new thread? Check the wiring, if it's good, get a new CPS.
code 4 is the Crankshaft sensor in the distributor - usually means you need a new distributor - could also be intake camshaft timing not correct, but if it was running before, it probably needs a distributor
Airbag Club
11
Mar 10, 2005 03:05 PM
