Steering wheel question
Does any one know if there are any Honda airbag assemblys that will match up with an rsx steering wheel, so that I can replace my acura emblem or are their any other suggestions.
I 2nd that question... any answers would be appreciated!
Also, are the silver center caps on 02-04 RSX-S wheels the same color silver and same fitment as the Honda center caps that can be bought?
If you want a fully functional airbag that will fit inside the RSX steering wheel, an 02-05 Civic Si airbag ONLY. The Type-R equivalents (EP3R/DC5R) will NOT be functional.
I have done this modification myself along with countless others.
Aren't airbag fitments specific to a particular model? I'd assume it takes into consideration all other design parameters such as unibody structure, seat position, vehicle weight etc. therefore using a different assembly could be hazardous. If passive restraint safety is not an issue, an aftermarket or racing wheel may be an easier solution.
streetsold6teeny8
Jan 15, 2010 04:52 AM
