Weird Shift Linkage Problem
Old Mar 9, 2007 | 11:09 AM
drshottest718's Avatar
Default Weird Shift Linkage Problem
Hi I swapped in a B16 with LS tranny and the shift linkage is sitting very weird. In neutral it sits like its in reverse and in order to get the shifter through the hole under the car, I had to throw it into 3rd gear and like bang it in. I figured since it was b16 linkage I should use gsr, so I changed it out and had the same problems. Its like the linkage is too long for the car (EG). What could the problem be? Im using Innovative Billet Mounts and a GSR rear bracket. I would really appreciate it if someone can help me figure this out.
Old Mar 9, 2007 | 02:06 PM
Default Re: Weird Shift Linkage Problem (drshottest718)
bumppppppp
Old Mar 9, 2007 | 02:07 PM
GYChris's Avatar
get somebody to cut and weld it shorter
Old Mar 9, 2007 | 03:06 PM
Default Re: Weird Shift Linkage Problem (slowEGchris)
i can probably do that but the problem is bigger than just it being long. Its supposed to be a direct swap and the linage is supposed to fit. Anyone have any other ideas?
Old Mar 9, 2007 | 03:09 PM
fmrprojects's Avatar
you should be using a gsr shift linkage. both linkages not just one
Old Mar 10, 2007 | 07:22 AM
Default Re: Weird Shift Linkage Problem (fmrprojects)
bump. I am using GSR linkage. Sorry if its confusing but I am using GSR linkage. Still got the problem.
Old Mar 10, 2007 | 08:01 AM
maynards_ek's Avatar
I could be wrong about this (i've never swapped an eg personally) but i thought my buddy had to cut the sheet metal back further on the transmission hump and then weld in a plate to reposition the gsr linkage. I do not speak from experience, just simply repeating what I was told.
Old Mar 10, 2007 | 09:03 AM
sevndaythry's Avatar
Default Re: Weird Shift Linkage Problem (maynards_ek)
Depending on the year of the car and the year of the engine, you might need a different transmission bracket (the one in the back). I believe the one you should be using is from a 3rd gen integra. But in all honesty the shift linkage should be the right length. Check the motor mounts, to make sure the engine is sitting in there properly.
Old Mar 10, 2007 | 10:50 AM
solfly's Avatar
is it a regular EG coupe hatch or sedan or is it a del sol
del sol linkage is shorter
KOALA YUMMIES
Apr 10, 2022 07:43 AM
1994CivicGS-R
Jan 17, 2006 02:42 PM
Egone
May 25, 2005 12:35 PM
