Issue with one-tire-fire
I have an issue with my passenger's side tire. It keeps going bald on me
AND when I step on it, it pulls to the right quite significantly.
At first I thought it may be an alignment issue. So I had a full alignment done. Didn't fix it.
Then I thought, crap - I wonder if someone replaced the tranny right before I bought the car with a NON-LSD one... which would really suck... and I couldnt find the LSD stamp on the tranny. So I did some honda-tech searching
and found that when the car is in the air, I can turn one tire and the other turns in the opposite direction - meaning yes, I do have LSD (phewf)
What could the problem be? Is it possible for the lsd to be "out of adjustment"? Possible my passenger's side A-arm is ever so slightly bent?
Ideas?
thank you
AND when I step on it, it pulls to the right quite significantly.At first I thought it may be an alignment issue. So I had a full alignment done. Didn't fix it.
and found that when the car is in the air, I can turn one tire and the other turns in the opposite direction - meaning yes, I do have LSD (phewf)What could the problem be? Is it possible for the lsd to be "out of adjustment"? Possible my passenger's side A-arm is ever so slightly bent?
Ideas?
thank you
I'd do some more research into that whole turn one tire in the air and the other spins the opposite direction. I seem to remember my LS doing that as well.
We had to take one of the wheels off while it was in the air and I had to go to the other side and try to hold the wheel still while my friend took the nuts off.
I think the best way for you to tell is pull one of the axels out, then shine a flashlight in the differential hole. If you see a bar in the middle of the hole, you got had. If you see the other axel with nothing in the middle of the differential, you have an LSD.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR »</TD></TR><TR><TD CLASS="quote">I am just pulling this out of my ***. compliance arm</TD></TR></TABLE>
Holy **** that must have hurt
https://honda-tech.com/zerothread?id=1735574
Hmmmmmmmmmmm
Ok, I'll check it out. Hope I wasn't had.... (everything else has been fine!)
Hmmmmmmmmmmm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrew Sutherland »</TD></TR><TR><TD CLASS="quote">I have an issue with my passenger's side tire. It keeps going bald on me
Ideas?
thank you
first off OEM LSD is a load based setup so can it not be checked with both wheels up in the air. If you do it that way it will work exactly like you mention, which is the way an open (non-LSD dif) works also.
the best (see non destructive) way to make sure you have an OEM LSD is to pull the axles and make sure there is no bar running across the middle of the axle holes.
bar = standard dif
no bar = LSD
Other ways of checking for LSD are a little more involved. Other than a little burn out, you can also turn the wheel one turn (with a lot of pavment in front of you) and simply stomp on the throttle, if the inner tire spins and the car accelerates slowly then you likely have an open dif. If the inner tire start to spin then the car sort of stutters a little and then the car accelerates close to what is does with the wheel straight then you have LSD.
As far as your one tire destruction problem... how hot is your rim/tire after driving a short distance? (dead give away to a stuck floating pin on the caliper)
Ideas?
thank you
</TD></TR></TABLE>first off OEM LSD is a load based setup so can it not be checked with both wheels up in the air. If you do it that way it will work exactly like you mention, which is the way an open (non-LSD dif) works also.
bar = standard dif
no bar = LSD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket »</TD></TR><TR><TD CLASS="quote">
You bish.... If you are gonna quote, quote it correctly like this.
Holy **** I am gonna get teabagged @ Expo
</TD></TR></TABLE>You bish.... If you are gonna quote, quote it correctly like this.
I guess my question to the O.P. is, Are you constantly doing burnout's?
IMO, you are suffering from a serve alignment issue and you say you had your aligment checked. Something in there is causing your aligment to go WAY out if you are significantly pulling to the right on acceleration. An LSD finaldrive... etc etc is not going to cause that.
You never stated whether or not it is the inner tire, outer tire or all of it that is going bald.
You would think the car wouldn't align properly if there were any bent suspension parts.
What type of suspension is on your car?
Like John said, inner tire or outer tire going bald?
Maybe your wheel is bent crazy or something.
All good thoughts. To answer some questions:
-Not a rim issue, I switched rims with the back tire and it is still doing it.
-Inner tire is getting the majority of the baldness.
-All OEM susp parts except for H&R sport springs and a camber adj kit.
-NOT doing ANY burnouts. I never ever beat on my car like that.
-I wasn't thinking a LSD would cause it to pull to the one side, I was thinking NOT having one would...
-Tire/Rim not hot, or at least not hotter than any of the other ones.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "Relic1" »</TD></TR><TR><TD CLASS="quote">you can also turn the wheel one turn (with a lot of pavment in front of you) and simply stomp on the throttle,... ... If the inner tire start to spin then the car sort of stutters a little and then the car accelerates close to what is does with the wheel straight then you have LSD.</TD></TR></TABLE>
BINGO - car does that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrew Sutherland »</TD></TR><TR><TD CLASS="quote">All good thoughts. To answer some questions:
Sounds like the passenger side slipped.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">
Sounds like the passenger side slipped.</TD></TR></TABLE>
Check that first, but like you said you had your alignment checked. I bet you have broken/worn bushings somewhere.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "Comp97GSR" »</TD></TR><TR><TD CLASS="quote"> Check that first, but like you said you had your alignment checked. I bet you have broken/worn bushings somewhere....... </TD></TR></TABLE>
Thanks, will do.
I'll post here to let you know if that was it!
Thanks, will do.
Thanks, will do.
I'll post here to let you know if that was it!</TD></TR></TABLE>
DId you check yet????? Hurry the hell up!!!!
refer to sig
Thanks, will do.
refer to sig
refer to sig</TD></TR></TABLE>
LOL Jim
. That made me chuckle........
LOL Jim
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrew Sutherland »</TD></TR><TR><TD CLASS="quote">Yes, but it's a matter of me finding it...
You arent gonna find it sitting behind the computer
</TD></TR></TABLE>You arent gonna find it sitting behind the computer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "walker111" »</TD></TR><TR><TD CLASS="quote">You arent gonna find it sitting behind the computer</TD></TR></TABLE>
Refer to your own sig
That is my answer...
That is my answer...</TD></TR></TABLE>
lol, but if your bored and drove the car......get your **** down and take a look!
What front camber kit are you using?
That is my answer...</TD></TR></TABLE>lol, but if your bored and drove the car......get your **** down and take a look!
Unfortunately I may be able to sneak some posts onto H-T, but I cannot leave work to go drive heR
Not for another hour and 10 mins though....
I can't remember what kit it was, I bought it off a guy on here...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrew Sutherland »</TD></TR><TR><TD CLASS="quote">Unfortunately I may be able to sneak some posts onto H-T, but I cannot leave work to go drive heR
I can't remember what kit it was, I bought it off a guy on here...</TD></TR></TABLE>
That sucks! I'm wondering if you have an adj camber kit up front, or just something like the ingalls kit.
