Opinon requested: New shocks and wheel hop
Old Mar 9, 2007 | 10:20 AM
Andrew Sutherland's Avatar
Default Opinon requested: New shocks needed
What do you guys suggest for new shocks?
I have H&R sport springs, a full front/rear camber adj kit, and STOCK ITR shocks. After I got the H&R's I was quite happy as the car still felt like it did when it was stock - tight, but not bumpy and rough like a lot of aftermarket suspension jobs. That's what I'd like to maintain now.
I believe I should replace my stock ITR shocks for 2 reasons - first being that they are still oem and have never been replaced, and I'm coming near 200,000 kms soon. Second reason is over the last few months I've noticed I get a LOT of wheel-hop rather than tire spin, even when the conditions are good. This didn't use to be the case, and I haven't changed anything in the suspension since then.
What brand/design of shocks would you suggest for an "oem feel"? Should I just replace them with oem shocks again? Or is there an aftermarket shock that is better quality and will last longer, but still have the same ride quality....
Old Mar 9, 2007 | 10:21 AM
OG undercover's Avatar
Default Re: Opinon requested: New shocks needed (Andrew Sutherland)
Wheel hop - motor mounts.
Old Mar 9, 2007 | 10:23 AM
donz's Avatar
Default Re: Opinon requested: New shocks needed (OG undercover)
wheel hop = traction bar too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "OG undercover" &raquo;</TD></TR><TR><TD CLASS="quote">Wheel hop - motor mounts. </TD></TR></TABLE>
Tried that. Put in Energy Suspension poly motor mounts.... car ran rough, didn't help with wheel hop, so I pulled them out.
Old Mar 9, 2007 | 10:24 AM
Default Re: Opinon requested: New shocks needed (donz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "donz" &raquo;</TD></TR><TR><TD CLASS="quote">wheel hop = traction bar too. </TD></TR></TABLE>
Tried that too... it's on there right now. Helps a little, but not near enough.
Old Mar 9, 2007 | 10:25 AM
donz's Avatar
Koni Red's are good if you don't need much adjustability... are you springs going bad?
Old Mar 9, 2007 | 10:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "donz" &raquo;</TD></TR><TR><TD CLASS="quote">Koni Red's are good if you don't need much adjustability... are you springs going bad?</TD></TR></TABLE>
I don't need much adjustability, no. How do I know if the springs are going bad?
Old Mar 9, 2007 | 10:30 AM
If that did not help... then check the air psi in the tires, I did motor mounts and trac bars and I have Zero wheel hop.
Old Mar 9, 2007 | 10:36 AM
The pressure looks ok, I think... 35 psi
What motor mounts did you use? I really did -not- like the energy susp ones. Made the car shake badly at idle etc...
Old Mar 9, 2007 | 10:45 AM
RTW DC2R's Avatar
its most likely your shocks. I am on the same setup and its getting progressively worse. However I do not have as many miles as you. I have super stiff mounts and my wheel hop is as bad now as its ever been. I feel my hop problems are mainly suspension related.
tire wear and pressure, alignment settings, suspension, motor mounts, clutch all play a part in wheel hop.
Old Mar 9, 2007 | 10:46 AM
looks like you have some wheel alignment issues. Get them fixed before anything else. It might solve your wheel hop.
Old Mar 9, 2007 | 10:50 AM
RTW DC2R's Avatar
dont you worry mr queentitaniumglassundercoverstunna itr guy
Old Mar 9, 2007 | 10:55 AM
white rocket's Avatar
Default Re: (I love lamp.)
Andrew, personally I would look into a set of Koni yellows, They would match up perfectly to your current H&R springs. The do have damper adjustability, which you mentioned you didn't need, but for the $$$ they are great.
Old Mar 9, 2007 | 12:06 PM
Default Re: (white rocket)
Thanks for the help/suggestions everyone. I too think it's shock related, as really nothing else has changed, but it's getting worse and worse as time goes on.
Would the Koni yellows still provide that nice luxurious Acura ride that I'm accustomed to though? I really don't want to go over a small bump in the road and feel my eyes shake in their sockets...
Old Mar 9, 2007 | 12:28 PM
rzz's Avatar
rzz
If u don't need damping adjustable, blistein is a really good choice too
btw, I believe koni red may be already discontinued because koni-na website doesn't list the koni red for itr
Old Mar 9, 2007 | 12:57 PM
itrdave's Avatar
Default Re: (Andrew Sutherland)
I have Koni Yellow on stock springs - they feel just like stock shocks at the softer end, but you can stiffen them significantly to suit stiffer springs and/or autocross/race requirements.
portaman03
Honda Civic (2001 - 2005)
18
Jun 5, 2007 01:43 AM
sleeperteg
Mar 7, 2006 06:38 PM
aleks77
Aug 13, 2005 02:38 PM
aleks77
Jun 2, 2005 08:54 PM
ShAAdiiiNG
Dec 28, 2002 10:23 AM
