1991 engine swap
Old Mar 9, 2007 | 12:08 AM
straightRazor's Avatar
Default 1991 engine swap
i am looking to pick up a used engine to dropinto my car i just want to know what engines will bolt onto my stock tranny. the car is a 91 rs with a dohc engine. i am thinking an engine makeing around 200 hp would be nice give or take a bit
Old Mar 9, 2007 | 08:05 AM
Rikter's Avatar
No engine will drop right into your car making 200hp.
Wiring, mounts, possibly axles, ecu, etc. Welcome to the world of a swap. Not that easy to get that hp with a direct bolt in.
-Rik
Old Mar 9, 2007 | 08:08 AM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: (Rikter)
there is no engine that will bolt in using your stock tranny that will make that hp
Old Mar 9, 2007 | 08:23 AM
da6jdmteg's Avatar
Default Re: 1991 engine swap (straightRazor)
of course any b series will bolt to that tranny. with an rs tranny id find something else unless you plan to go turbo. if you want 200 horse power bo for the b16 b.
Old Mar 9, 2007 | 08:26 AM
Lewy. Dee Ayy's Avatar
ITR swap with a cable b16 or b17 trans. or hydro to cable swap and ITR trans ITR = integra type r
http://www.hmotorsonline.com/s...30010
thats as close as ur gonna get to 200hp with a stock b series
30011 - B18C 96-00 (TypeR) Complete Change Over
200Hp 134Trq 11.1 Compression(JDM)
195Hp 130Trq 10.6 Compression (USDM)
$ 4400.00 Plus shipping and handling 96-97 Spec
$4950.00 Plus shipping and handling 98Spec+
Old Mar 9, 2007 | 12:38 PM
Default Re: 1991 engine swap (Lewy. Dee Ayy)
i said around 200 160-180 i think is more likely
i am thinking about takeing the bottom end out of a b16 an puting a b18 top end on it. my mechanic said it would work.
sde780
49
Jul 26, 2009 07:47 AM
dj273
Jun 4, 2007 07:34 PM
k0sov
Jul 12, 2004 10:50 PM
