T3/T4 60 Trim .60/.63 AR on B16?
http://forums.evans-tuning.com...=3809
http://forums.evans-tuning.com...=3797
http://forums.evans-tuning.com...=3618
http://forums.evans-tuning.com...=2214
These are 57 trim I believe but close enough to give you an idea. Turbo lag is not only determined by the turbo. THe manifold, down pipe cams, etc... have a dramatic affect on lag. This turbo is not SUPER crazy so don't sweat it. ALso look at hp level when looking for a turbo. I read the gt28rs is pretty sick and has great spool up and some people have made 400+.
this is the turbo you ask of but ona gsr with alot of boost.
http://forums.evans-tuning.com...=2607
But the turbo is the main component that determins HP limit and lag. 300whp is easy to get with a 50trim t3/t04e, and even that has another ~75-100hp left. A 60trim T3 .60/.63 stg3 exhaust would be perfect for a bit over 300whp and a quick spool/low lag.
FYI the first b16 I did some tuning on was a 60trim T3, .60/.63 stg1 exhaust. Before I touched the uberdata map, it made ~250whp at 9psi. These turbos can make 15psi+ w/o "pushing hot air", so 300whp on a smallish turbo isn't hard to do.
I run the same turbo in a 57 trim on my stock b16 and I love it. Like those dyno graphs showed the power comes on right abought 5000 rpms just befor vtec engages.
Honda thought It would be a good place for the for the motor to scream and I agree.
I like the part throttle to cause with the .63 ar it does not go in to boost so easily like a smaller turbo.
Thanks a whole lot. You helped out big time. I am thinking about getting the gt2860rs but I am not sure if its in my budget. Is there a huge differance in the powerband with the gt28rs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ak_ef9 »</TD></TR><TR><TD CLASS="quote">Thanks a whole lot. You helped out big time. I am thinking about getting the gt2860rs but I am not sure if its in my budget. Is there a huge differance in the powerband with the gt28rs?</TD></TR></TABLE>
The ball-bearing turbos dont necessarily spool up faster but they dont fall out of boost as fast as a thrust bearing turbo. For example, when you shift gears the ball-bearing turbo will hold its spool longer than a thrust bearing turbo, because of this the driveability/streetability of a ball-bearing turbo is superior.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegdude227 »</TD></TR><TR><TD CLASS="quote">bump for more info on the GT3251E and i did search </TD></TR></TABLE>
you're not going to find a whole lot about it....the best way to find out info on it is to PM TheShodan and talk to him about it
