((WHAT GAS?)))
Old Mar 8, 2007 | 10:28 PM
in10ceCiviC's Avatar
Default ((WHAT GAS?)))
i gotta LS/V
95 b18 LS block w/ a 92 GSR HEAD n TRANS....
can i use 87 octane in my car?
Old Mar 8, 2007 | 10:30 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
why would you want to do that? wouldnt you want the highest octane for more combustion.
Old Mar 8, 2007 | 10:31 PM
crowder13's Avatar
i think u can, car will run/ feel like crap, Just pay the extra 2 dollars and put premium in it
Old Mar 8, 2007 | 11:54 PM
krytoi's Avatar
dont be cheap u dont wna break the engine just give it premium and it will be good
Old Mar 9, 2007 | 06:45 AM
Wraith_G2IC's Avatar
Default Re: (krytoi)
Holly knee-jerk reactions.................. What is wrong with you chuckle-heads?
Hear this now and understand it later, higher octane fuel does NOT benefit low compression engines. PERIOD. And VTEC does not automatically = premium octane fuel. Look at all the SOHC VTEC Civics out there. What fuel does Honda specify for them? Oh that's right 87 octane.
OP, you didn't mention changing any thing like pistons or going with a crazy thin HG on a shaved down head so here are some rough numbers for reference.
Stock B18B compression is ~9.2:1
Stock B18B + B17A1 head, compression is ~9.5
Honda recommends for all 86-01 Integra RS/LS/GS, use 87 octane fuel, preferably from a TopTier fuel provider like Shell. http://www.toptiergas.com That being said, your engine and compression ratio do not warrant premium octane. A VERY general rule of thumb is 10.0:1 or higher will "need" premium octane fuel or higher. On the other hand you will want to have your car tuned so you can get the most power + efficiency out of your setup. There are a lot of factors such as timing, ECU programing, etc... that can lead to knocking an pinging. Just throwing high octane fuel at an un-tuned setup to try preventing knock & ping is not the right way to go about it.
Old Mar 9, 2007 | 06:50 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Since the B18B does not have a knock sensor, I would say that if you're modifying and tuning your car, you should run at least 91 octane just to be safe, since the car will not retard timing by itself if pre-detonation occurs.
Old Mar 9, 2007 | 08:11 AM
zer0bot's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Since the B18B does not have a knock sensor, I would say that if you're modifying and tuning your car, you should run at least 91 octane just to be safe, since the car will not retard timing by itself if pre-detonation occurs.</TD></TR></TABLE>
Old Mar 9, 2007 | 11:43 AM
Default Re: (Wraith_G2IC)
well i was jus wondering..........................i do put 92 but i wanted to know if u can run 87 i dont think iwas going to change..here in hawaii its all like a couple cents diff anyways................
92 is like $2.80 gal.
Old Mar 9, 2007 | 01:24 PM
doood's Avatar
been there done that
Default Re: ((WHAT GAS?))) (in10ceCiviC)
if the block is still bone stock just run 87
Circusraven
Aug 2, 2008 01:14 PM
jdm_SirG
Mar 8, 2006 02:37 PM
94si94cx
Oct 1, 2002 07:20 PM
Charlie Moua
May 31, 2002 07:05 PM
EVOCELICA
Jul 9, 2001 04:34 PM
