Sidemarker Lights
Ok. So I just got some new sidemarkers and it doesnt look like the wires are very long. how do i wire these, should i splice some longer wires to these and then splice to signal lights, or should the wires in the fender be long enough to reach?
I got some wire laying around but its a just a little bigger guage then the pigtail wires coming off the sockets it will still work tho if i crimp em together? how much wire should I need for the wire i crimp on to run to splice to the signals? Oh and what color wires and where are they located for the parking/signals, I just see some wire in the fender running to the door from inside the fender
go to walmart and buy some green and black 12guage electical wire in the auto parts section, then run the black and green wire from where ever your going to mount the sidemarkers and then you will want to run the wires on the inside of the fender into the engine bay next to the cornermarkers, i believe the corner markers have three wires, one is white the other is black and the third is green. then with the black and green wire you ran from the sidemarker, splice the green and black wire into the same color wires for the corner marker. and your set
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CapnKrunch »</TD></TR><TR><TD CLASS="quote">Sounds good. Thanks alot
no prob
no prob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiYouLater »</TD></TR><TR><TD CLASS="quote">I recommend soldering extension wires with shrink wrap and using wire taps to tap the signal lights.
Solder and Shrink Wrap FTW... looks clean and professional.
</TD></TR></TABLE>Solder and Shrink Wrap FTW... looks clean and professional.
prelude182
Feb 24, 2011 11:23 AM
90_EX_Civic
Mar 21, 2009 07:59 PM
