03 Accord 4 cyl Rough Idle
Old Mar 8, 2007 | 06:47 PM
rfossett's Avatar
Default 03 Accord 4 cyl Rough Idle
My wife's 03 Accord, 4 cyl., has developed a rough idle that when the AC compressor kicks on or the car is in gear. It is bad enough you feel the roughness in the steering wheel or feel vibration with your feet. I watch the rpms and they dont drop. But something is really causing this motor to vibrate the car enough we now have a rattle in the dash. The car has 69000 miles with no other problems, brought in and serviced by Honda dealerhip as per Honda recommendations. The dealer had had the car over four days trying to find the problem. An Idle kit Honda came out with was installed, didnt work...changed front motor mount...didnt work...re-torqued engine mount bolts...didnt work either. The mechanic cannot find the problem....Honda Tech told the mechanic that it is a 70000 mile car...COP OUT BIG TIME! My wife has had a new Honda Car since 94 each body change and has never had this happen before... DOES anyone have any ideas on what the problem might be???? Your help will be greatly appreciated!
Old Mar 9, 2007 | 04:26 PM
gulfview's Avatar
Default Re: 03 Accord 4 cyl Rough Idle (rfossett)
Unless you can find a more qualified mechanic locally, you could give a try to JustAnswer.com on the internet -- it provides advice by experienced Honda mechanics.
jerryjike
Jun 19, 2018 03:46 PM
EVS90
Mar 22, 2014 03:42 PM
MaTt16289
Mar 15, 2006 09:50 AM
