I did 125mph on a residential
Old Mar 8, 2007 | 05:34 PM
lacking vtec's Avatar
Default I did 125mph on a residential
no, not really. i'm not that dumb...but my speedometer is actin up. it would go up to the actual speed im going but will never go back down when i deccelerate; so it would add up my speeds every time i stop and go. has this ever happened to anyone before? i'm thinking the cold might have something to do w/ it.
Old Mar 8, 2007 | 06:36 PM
Import_spoon's Avatar
I was about to say you better put on a flame suit. I think its your Speed Sensor wires or the Speed Sensor teeth are messed up. Happened to me when I was learning to drive stick on my Integra.
Old Mar 8, 2007 | 07:13 PM
Default Re: (Import_spoon)
speed sensor...is that the cable coming from the gauge cluster goin to the tranny? how do i fix it if it's "messed up?"
Old Mar 8, 2007 | 07:23 PM
thewrai6th's Avatar
Default Re: (FlipTheHater)
The VSS works on 5 volt pulses, spin one tire and check for the pulse on the VSS wire in the gauge cluster. Could be a wire on the back of the manifold grounding out. The manual has a VSS troubleshooting section.
http://www.hondahookup.com
Lokisdope
Jul 5, 2019 05:02 PM
CORE132
Mar 3, 2013 04:04 AM
96honda_EK
11
Oct 20, 2009 03:40 AM
foxdecoy
Aug 21, 2009 03:41 PM
ugly rex
Jan 1, 2007 11:19 PM
