Need help!! swap searched!!
Old Mar 8, 2007 | 05:21 PM
CiviCVuE's Avatar
Default Need help!! swap searched!!
I have a 95 obd1 gsr motor and I am swapping it into a 98 civic that was stolen and stripped. I have purchased a 99-00 si engine harness and ecu jumper and all mounts. I need to know what wiring will be ness. using the si engine harnes. Thanks in advance
Old Mar 9, 2007 | 03:32 AM
CiviCVuE's Avatar
Default Re: Need help!! swap searched!! (CiviCVuE)
bump
Old Mar 9, 2007 | 04:31 AM
jungletronic's Avatar
I would use 96-98 Civic harnesses and parts from the Si engine harness.
Old Mar 9, 2007 | 07:33 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Need help!! swap searched!! (jungletronic)
most of the plugs on the intake manifold will have to be spliced with the OBD1 harness depending on what ECU you are using, i can tell you the whole story. What ecu are you using? You will have to get an ECU side jumper harness from OBD2B - OBD1 (If you have the 95 GSR ecu). Otherwise, everything should be the same. You just kinda have to splice plugs as you go on the ENGINE side. Where the wiring harness plugs into the intererior harness (The green plug located right by the ECU plugs) will probably have to be spliced out for the 98 green plug if im not mistaken.
Old Mar 9, 2007 | 02:47 PM
CiviCVuE's Avatar
Default Re: Need help!! swap searched!! (B serious)
I am using the p72 that came with the gsr and the green plug on the si harness is not the same. so I think i am in for a ride. any help would be greatfull, thanks
clark81
Sep 5, 2010 11:52 AM
EK9_love
May 31, 2009 04:50 PM
Jdmdctek
Jun 11, 2007 07:55 AM
dizzyek
Feb 9, 2006 01:50 PM
B18ek
Nov 27, 2004 07:39 AM
