how much power will this turbo support??
Well to start off here are the specs of the motor:
Dart B18 block 84mm bore
LS crank
Ross pistons
manley rods
ported gsr head
full ferrea valve train including the roller rockers
crane/ferrea cams
custom sheet metal intake
precision 750hp intercooler
3" charge pipe
LoveFab mini-me eq manifold
3"lovefab dp
LS crank
Ross pistons
manley rods
ported gsr head
crane/ferrea cams
3" charge pipe
3"lovefab dp
hahah my bad I copied and pasted from the drag racing forum and missed that sorry...
the turbo is a t4/60-1 .81ar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeimbo »</TD></TR><TR><TD CLASS="quote">probably about like 200whp</TD></TR></TABLE>
lol
lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tokes1320 »</TD></TR><TR><TD CLASS="quote">Way to not tell us what type of turbo you're thinking of running </TD></TR></TABLE>
Hahah!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacingProducts »</TD></TR><TR><TD CLASS="quote">hahah my bad I copied and pasted from the drag racing forum and missed that sorry...
A t4/60-1 is rated at 550hp.
Hahah!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeimbo »</TD></TR><TR><TD CLASS="quote">my t3/60-1 is rated to like 560 i think, i would think that the t4 would be rated to like 600ish+ whp.</TD></TR></TABLE>
550hp was from memory, its actually 585
Close enough.
T4/60-1
"The infamous 60-1 turbocharger with a T4 turbine for additional power.
Compressor Specifications:
-60-1 compressor wheel with a max flow rate of 61 lb/min
-0.70AR T04S compressor housing
-Good to 585 whp.
Turbine Specifications:
-p trim turbine wheel available
-0.68 AR , 0.84 AR, 0.96 AR tangential housing options
-v-band turbine discharge
CHRA Specifications:
-360 degree thrust bearing standard.
-Oil cooled&lubricated center section. "
Copied from Full-Race.com:
http://www.full-race.com/catal...d=253
Close enough.T4/60-1
-Good to 585 whp.
