HELP WITH EGR VALVE
Old Mar 8, 2007 | 03:14 PM
Electron_Blue_Kid's Avatar
Default HELP WITH EGR VALVE
how hard it is to replace an EGR valve on a civic my scanner indicates there's a problem with not enough or to much something to do with the exhaust? If you have any input please let me know little red is dragging and idling like crap gas mileage still about 380 per tank
Old Mar 8, 2007 | 11:06 PM
PelicanBince's Avatar
Default Re: HELP WITH EGR VALVE (Electron_Blue_Kid)
What kind of vehicle is it (generation/motor)?
Old Mar 9, 2007 | 01:56 PM
Default Re: HELP WITH EGR VALVE (PelicanBince)
1997 hx coupe
d16y5 vtec-e
Old Mar 12, 2007 | 08:09 PM
anyone?
Old Mar 20, 2007 | 10:59 PM
typeSH714's Avatar
i hav the same problem. is it the code p0401: EGR flow insufficient.?
if so, don't replace ur EGR valve. i tried cleaning out my egr, running some seafoam through the egr ports, and i even replaced the egr valve and i still hav the cel. im still trying to figure out how to fix it.
Old Apr 2, 2007 | 06:04 PM
BigMoose's Avatar
Default Re: HELP WITH EGR VALVE (typeSH714)
The bigmoose needs help here also. P0401 code on my 1997 Civic HX D16Y5 with 180,000 miles on it. I cleaned the EGR valve thoroughly. Code reset. I disassembled the EGR Valve and verified the EGR lift sensor, valve lift and flow. Code reset. I rodded out the manifold passages and blew air thru them. Code reset.
Insight would be much appreciated!
Old Apr 2, 2007 | 06:12 PM
JDMFantasy2k's Avatar
Default Re: HELP WITH EGR VALVE (BigMoose)
why don't you guys try spraying brake cleaner through the egr passage ways. Then see if you can get some sort of pipe cleaner in there, like the kinds they use to clean out household furnaces, they have long flexible handles. And yeah try cleaning the valve itself. If that doesn't work, check your map and O2 sensors. Not sure how honda does it but i know GM will check for EGR actuation by looking for a decrease in manifold pressure for when EGR opens and many manufactures will use O2 input as well because there should be far less oxygen in the exhaust when EGR is working.
Old Apr 5, 2007 | 05:25 PM
BigMoose's Avatar
Ok, to help you other guys out. Got it solved here is the solution.
I tried to do a quick and dirty clean/blow out with air thru the EGR opening in the intake manifold. It didn't work. Take a few minutes, and remove the fuel rail and the fuel injectors. Then remove the top plate of the EGR section of the manifold. There are 6 screws that hold the cover on. If you are in the salt belt like me, the 6mm bolts will be corroded, they will want to snap. You don't want to drill and tap 6 of these! Heat the head of the bolt a bit, back it out a bit, then hit the head with a hammer thru a punch. This will break the corrosion bond. Keep this cycle up until you get the bolts out.
Then clean it up with a scraper and some carb cleaner. Ream the 4 holes out (about 3/16 inch diameter) that go into each runner from the main EGR cavity. Clean, reassemble and you will be good to go.
There was nothing wrong with my EGR Valve, and the serpentine EGR passsages were plugged solid their entire 4 inches.
Old Mar 24, 2009 | 04:23 PM
STREETFIGHTER50's Avatar
Back from the dead! Is this the only way to thoroughly clean the EGR system out? Any easier soutions?
truword1
Honda Civic (2001 - 2005)
Mar 5, 2009 04:44 PM
Linh.
Dec 10, 2005 10:03 AM
mtfishin
Nov 8, 2004 06:35 AM
munscher
Nov 24, 2002 04:48 PM
