C-Pillar bar on 99 Coupe?
Old Mar 8, 2007 | 10:56 AM
Sp00nFed EM1's Avatar
Default C-Pillar bar on 99 Coupe?
I know when I had my c-pillar bar in my DA it was simple, just had to remove the rear seatbelts and it bolted to the bolt there. Anyway, I just ordered one for my 99 SI and was wondering how I install it since the seatbelts in the back come from the trunk cover where the speakers are? Anyone have one on a coupe and can supply some info and even pics about this install? TIA!
Old Mar 8, 2007 | 10:57 AM
Eran's Avatar
HT White Ops
You're probably going to have to cut holes in your c-pillar garnishes and tap a bolt into them.
Old Mar 8, 2007 | 11:06 AM
pdiggitydogg's Avatar
Return it - its completely useless on a coupe because there is the rear deck brace behind the seats.
If you really want to install it (stupidly) you will have to cut holes in the trim and weld or drill/tap it to the pillar, itself (without nuts behind those taps, it will tear out anyway though)
Old Mar 8, 2007 | 11:50 AM
B16b-EJ8's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Return it - its completely useless on a coupe because there is the rear deck brace behind the seats.
If you really want to install it (stupidly) you will have to cut holes in the trim and weld or drill/tap it to the pillar, itself (without nuts behind those taps, it will tear out anyway though)</TD></TR></TABLE>
x2 this guy is 100% correct
Old Mar 8, 2007 | 01:38 PM
actually i just saw a pic of it moutned behind the driver/passeneger headrest, on that pillar...looks good
typed in c pillar bar here on h-t search...
ill post a pic or link in a sec...
Old Mar 8, 2007 | 01:43 PM
B16b-EJ8's Avatar
Default Re: (Sp00nFed EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sp00nFed EM1 &raquo;</TD></TR><TR><TD CLASS="quote">actually i just saw a pic of it moutned behind the driver/passeneger headrest, on that pillar...looks good
ill post a pic or link in a sec...</TD></TR></TABLE>
I would love to see the picture in order to properly identify it for you...other than that its your car and your monkey bars do with them as you wish
Old Mar 8, 2007 | 02:17 PM
https://honda-tech.com/zerothread?id=1712154
Old Mar 8, 2007 | 02:38 PM
seabass10369's Avatar
that pics of it are not on a coupe thats a hatchback, coupe is useless, if it were me id go to the local ricer hang out and try and sell it to some dumb ****
Old Mar 8, 2007 | 02:43 PM
B16b-EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sp00nFed EM1 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1712154</TD></TR></TABLE>
well in the description
Fits 92-95 Civic 2/3/4 door, 96-00 civic 3 door and 94-01 Integra.
DA/EF ALSO AVAILABLE!!!
it says for 96-00 civic 3 door so that would leave me to belive that i will not work on a coupe
Old Mar 8, 2007 | 02:47 PM
CeeJayy's Avatar
Default Re: (B16b-EJ8)
http://sparcousa.com/harness_bars.asp
go there they have what your looking for at least the kind i think ahaha..
Old Mar 8, 2007 | 02:55 PM
B16b-EJ8's Avatar
Default Re: (CeeJay16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CeeJay16 &raquo;</TD></TR><TR><TD CLASS="quote">http://sparcousa.com/harness_bars.asp
go there they have what your looking for at least the kind i think ahaha..</TD></TR></TABLE>
That is a harness bar...for mounting a racing harness to but would probably suit the look you are going for
Old Mar 8, 2007 | 03:29 PM
in that link theres a pic of a civic coupe it says civic club or something on the side/rear windows, the bar sits on the pillar between the two windows, and its a megan bar.
What about if I used that c pillar bar in the spot im describing, behind the headrests from pillar to pillar and used it for my takata harnesses since I have OEM seats still. Do you think this will work?
Old Mar 8, 2007 | 03:40 PM
B16b-EJ8's Avatar
I wouldnt do it especially since it was not designed to support a harness, and chances are it will be to short to stretch that sitance since the interior tapers down towards the back...i think (im not in my car)
Old Mar 9, 2007 | 09:25 AM
damn, i gues this is what i get for rushing and ordering **** with out looking @ the description in detail.
Old Mar 9, 2007 | 10:00 AM
B16b-EJ8's Avatar
It happens to the best of us you should be able to return it. Just let the seller know that it does not work for your application, if the seller is worth anything they will refund the money
Old Mar 10, 2007 | 06:21 AM
cool, THANKS!
Old Mar 11, 2007 | 03:54 PM
So does anyone know if this C Pillar bar will fit where Im trying to put it, behind the front headrests, the pillar between the front and rear windows on a ek coupe?
Old Mar 11, 2007 | 04:00 PM
19992civichatch's Avatar
im sure you can make it fit, but why would u. just type in b pillar bar and see what comes up on ebay, and why do u want to put it behide ur head rest
Old Mar 11, 2007 | 05:34 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sp00nFed EM1 &raquo;</TD></TR><TR><TD CLASS="quote">So does anyone know if this C Pillar bar will fit where Im trying to put it, behind the front headrests, the pillar between the front and rear windows on a ek coupe?</TD></TR></TABLE>
No.
That crap doesn't do anything to begin with, so why waste your money? Save it or buy something worthwhile.
Old Mar 11, 2007 | 05:59 PM
stuntinhb's Avatar
I guess it would make for a good coat hanger
Old Mar 12, 2007 | 07:15 AM
but will it fit you think?
Old Mar 12, 2007 | 07:18 AM
It would be more than retarded, between the b pillars...
If you want to do it, go ahead...serves no purpose other than ridiculousness.
It will probably be too short to fit...but why dont you just go out and try it, rather than continuously asking "will it fit?"
Old Mar 12, 2007 | 08:54 AM
This forum sucks, nobody helps anyone and if you read I dont have it yet...
Old Mar 12, 2007 | 09:00 AM
B16b-EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sp00nFed EM1 &raquo;</TD></TR><TR><TD CLASS="quote">This forum sucks, nobody helps anyone and if you read I dont have it yet...</TD></TR></TABLE>
I beg your pardon...but i believe i offered plenty of help, and so have others....you just chose not to accept their help or information. As stated before i dont think it will reach from "b" pillar to "b" pillar. It may work on the c pillar however you would have to cut the platic drill and tap some holes. This is the best information we can offer you since you bought the wrong part...you are saying no one wants to help however you even admited to buying the wrong part so how can anyone give you accurate information since most people can attest to using the right part for the right application, not the wrong one.
Old Mar 13, 2007 | 07:51 AM
http://i6.photobucket.com/albu...y.jpg
Look how they have it?
Its in most of the pics on that page...idk tho.
