rsx bulb went out on dash please help
ok on my rsx the last **** for the ac... the light went out i taped the dash and it lights back up only sometimes.???? has this happen to anyone and how can i fix this? i know a bulb but how do i get back there?
same thing happened to me. its pretty easy. go to honda or acura and get either part numbers 79670-SL0-A01 or 80629-S04-003 . it depends on which light is out and i forget which bulb is which so might as well buy both. its easy after that. take a screw driver pry out the entire climate control panel and then unclip it from the wiring harness. there are like 4 screws holding the back on it and then you can see the bulbs. the bulbs are the hardest part because they are so tiny so you need a 3/16 standard screw drive to unlock them from the circuit board. i just did this on monday so pm or email me with anymore questions.
mark31kiss
Mar 30, 2007 10:54 AM
79670sl0a01, 80629s04003, acura, bulb, bulbs, climate, console, control, dash, honda, lights, number, part, replacement, rsx
