GSR w/cams + light mods.....Tuning needed?
So, I have a 99 gsr swap i did, and over the winter here in montreal, i did the following mods: Type r cams,supertech springs,retainers, milled ALLOT off the head, CAI, headers,exhaust,7.5lb flyweel,pully kit, and i think thats it for the motor.
anyway, im running a stock p72 right now. is there any need for tuning? i have a p28 and a vtec-frog harness lying around i guess i could use. it seems to run ok at the moment. the mods arnt heavy on this motor, so im not sure the tuning is necesary.
Why did you mill ALOT off the head?
You do realize that it's bad to mill the head to get higher CR.. You end up killing your quench area and you'll lose power.
ANd good lord yes, please tune your car. Why would you do what you did and not tune?
You haven't even begun to hit the full pontential of those mods if you are still running off a stock ECU. Get it tuned, but more importantly, where are you going with the project? What are your goals? Its hard to tell with the mods you've done and "ALLOT of milling".
~Ben
~Ben
the head had to be milled down a little over the specs. it was warped preety bad. it wasent part of the build plan, trust me. i was just trying to save the engine.
and the reason i wasent sure if tuning was needed, is because the motors not heavily modified. just mostly bolt ons.
well, I appriciate all your input guys. thankyou.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec8804 »</TD></TR><TR><TD CLASS="quote">adding onto his ? what kind of power gains would u most likely be able to see with a tune say with hondata for ex. cams full exaust. is it worth the money? </TD></TR></TABLE>
Yes, it's worth the money. The stock ECU is putting the minimum out on those parts. Listen to everyone and get the car tuned. You'll be happy you did.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diagnostic »</TD></TR><TR><TD CLASS="quote">the head had to be milled down a little over the specs. it was warped preety bad. it wasent part of the build plan, trust me. i was just trying to save the engine.
well, I appriciate all your input guys. thankyou.</TD></TR></TABLE>
that milled head has now raised your compression ratio to god know's where. tune it if you want it to last.
u can usually expect 3-5 hp depending on how good the car gets tuned.
Combustion Contraption
17
Apr 13, 2004 07:06 PM
wuhungsixxx
Nov 21, 2001 02:24 PM
