'97 Integra LS turbo, S300
This was our first attempt at a complete install and tune, usually we just tune. I think it went quite well, thanks to Randy for his patience.
Tuned to 10.5psi
Tuned to 10.5psi
with that psi on a ls he could have mad 300whp but its all in the tune and thats prolly not the best numbers he could have got but i guess it depends on the set up he might have stock exhaust or something never no
That manifold is F-ed up. I'm not suprised it only came out with 210 hp.
Stock exhaust would also add to the low numbers dezerte. You should run at least 2.5" (3" recomended) piping in order to get good flow out of most turbo applications
~Ben
~Ben
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bendw99 »</TD></TR><TR><TD CLASS="quote">That manifold is F-ed up. I'm not suprised it only came out with 210 hp.
~Ben</TD></TR></TABLE>
From that picture, that manifold is not 'F-ed up'.. It looks like your average log manifold from which ive seen over 500hp pushed through.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoePSI »</TD></TR><TR><TD CLASS="quote">From that picture, that manifold is not 'F-ed up'.. It looks like your average log manifold from which ive seen over 500hp pushed through.
You are quite right sir. Well we gave it more timing, but it just did not like it and the use of those apc spark plug wires did not help either.
Also sporting the stock MAP sensor also prevented us from going any higher in the boost regions.
No we did not change the head gasket on it.
Yeah this is the first install and tune on a LS we have done. We have tuned UTEC on a Subbie, and several 350z, tuned several AEMs and many Hondata S200, S300.
So we are taking things slowly but surely.
210!! =/ thats kinda low..you should of tunned it with new injectors and a aftermarket fuel pump atleast...my brother has a turbo ls also and im positive that he will be hittin way higher numbers...='/
BoostedD15B7
Apr 16, 2003 09:13 AM
