Where can I get a heat shield for my log turbo manifold?
Hey guys I was wondering where i can buy a log turbo manifold heat shield like the one in this picture. Thanks.
make one.
Sheet metal @ home depot is your friend. They have different thicknesses.
Use cardboad to make a template, then cut final out of sheet metal and bend as necessary.
Hmm...OEM Mitsu heat shields have a layer of ceramic between metal layers to really keep heat out of the engine bay...think that's possible to make your own?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 »</TD></TR><TR><TD CLASS="quote">make one.
Use cardboad to make a template, then cut final out of sheet metal and bend as necessary.</TD></TR></TABLE>
sheet metal gets hot to. it wont do much for a turbo mani imo.. like the guy above said, a cermic coating around the metal would def. be good
Make heat sheild out of sheet metal.
Buy DEI exhast tunnel shield 20X21 ($21.99) and stick it to the top of the sheet metal. I would also add a bolt or two here and there even though the DEI stuf is self adhesive and VERY sticky.
I got some on my underside of my hood.
But the best thing to do would be to get header wrap and wrap the log mani instead of a heatshield. I did this as well as added a turbo blanket and I wrapped the downpipe too.
What I did REALLY keeps the heat in!
