15 x 7.5 Offset 38mm - OK on a 94 LS?
Old Mar 7, 2007 | 08:47 PM
Honda_Fanatic's Avatar
Default 15 x 7.5 Offset 38mm - OK on a 94 LS?
Just wanting to make sure that this is an ok rim size/offset.
Thanks
Also what size tire do you guys recomend for a rim this size?
My Setup:
1994 Integra LS
H22a4 w/ M2B4 LSD tranny
ESP Custom Header
Tanabe Racing Hyper Medalion 60mm Exhaust
Ebay Intake w/ K+N Filter
Chipped P06 (modded to be a p72) running crome
Hasport Mount Kit
Custom Homemade Axles (for now)
D2 or OMNI Coilover Kit (haven't puchased quite yet)
Explicit Speed Traction Bar (also on the list of future purchases)
Old Mar 7, 2007 | 08:52 PM
PrinceAli132's Avatar
Default Re: 15 x 7.5 Offset 38mm - OK on a 94 LS? (Honda_Fanatic)
This is not to helpful but a buddy of mine is running 15x7.5 +43 without issues. I am unsure of the tire size though.
Don't quote me on this, but I think you'll be fine. It just depends on your drop.
Ali
Old Mar 7, 2007 | 08:53 PM
GoldCoin's Avatar
Default Re: 15 x 7.5 Offset 38mm - OK on a 94 LS? (PrinceAli132)
my teg has rims with offset +55
Old Mar 7, 2007 | 08:54 PM
Tornadom's Avatar
7.5" is a bit wide, but it will fit never the less. I suggest 195/55 or 205/50 sized tires, or if available 215/50.
Old Mar 7, 2007 | 08:55 PM
Default Re: 15 x 7.5 Offset 38mm - OK on a 94 LS? (Tornadom)
With a 7.5 can't I go to even possibly a 225? or would that be too much?
Old Mar 7, 2007 | 08:56 PM
Blackturboteg's Avatar
I run 17's on my ls and run fine Wheel size: 17"x7" Weight per wheel: 17.84 lbs.
Bolt pattern: 4x100mm Offset: 40mm (1.57")
Has conical seats for acorn style lugs
Old Mar 7, 2007 | 08:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">With a 7.5 can't I go to even possibly a 225? or would that be too much?</TD></TR></TABLE>
I think you would be able to get away with a 225, depending upon the brand. Since Azenies width are a little on the big size where they're 205 is pretty close to a 215.
Try PM'ing Nsxtasy. He knows his ****, especialy when it comes to tires.
Ali
Old Mar 7, 2007 | 09:00 PM
Tornadom's Avatar
A 225 width tire will fit the rims nicely, but it is rare that a tire is offered in a 225 width that is the right height for an Integra. A 225/45 will be close to the same diameter as a 205/50 where as a 225/50 will be close to the same diameter as a 205/55. Toyo RA-1 are offered in 225/45/15 sizes that are nice on Integras.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tornadom &raquo;</TD></TR><TR><TD CLASS="quote">7.5" is a bit wide, but it will fit never the less</TD></TR></TABLE>
I want to get as much rubber on the road as possible
Old Mar 7, 2007 | 09:09 PM
Tornadom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">I want to get as much rubber on the road as possible </TD></TR></TABLE>
I can respect that. It is my goal to have as much quality rubber (Indiana Gummies anyone?) on the road as I can.
Old Mar 7, 2007 | 09:10 PM
lol, right on!
Old Mar 7, 2007 | 10:36 PM
can anyone guarantee fitment?
Old Mar 7, 2007 | 10:48 PM
GoldCoin's Avatar
i can guarantee.
Old Mar 7, 2007 | 11:05 PM
Default Re: 15 x 7.5 Offset 38mm - OK on a 94 LS? (DC TWOin IT)
thanks! any one have pics of his setup?
Old Mar 8, 2007 | 05:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">thanks! any one have pics of his setup?</TD></TR></TABLE>
Here's a 15x7.5 +43 (but I am unsure of the tire size)
Ali
Old Mar 8, 2007 | 07:58 PM
Old Mar 9, 2007 | 12:59 PM
ixcocoyxi's Avatar
would you have to roll fenders if running 195/50 15 w/tire tuck on that rim size and offset?
Old Mar 9, 2007 | 01:09 PM
GoldCoin's Avatar
Default Re: (ixcocoyxi)
na.
BROKE.eg
Suspension & Brakes
10
Jan 31, 2006 03:05 PM
2ndName
Jan 16, 2006 11:18 AM
sumyungguy
Dec 14, 2005 02:28 PM
sumyungguy
Dec 14, 2005 01:54 PM
thinkbrianthink
Jul 6, 2001 12:09 PM
