STD seat belt latch
i realized that my STD seat belt latch is on the seat. which models have the latch on the chassis so i can use my seat belts on new seats?
Modified by FotoGenetix at 9:51 PM 3/7/2007
88-89 models? I believe 90-91 are seat mounted. You could try mounting the seat belt latch on the seat frame. Seen that setup on a lot of aftermarket seat setups. Not sure how safe it is though.
anyone have a solution to using a stock seatbelt with aftermarket or oem seats w/o the seatbelt latch on the seats? i found that the hole for the 88-89 latch/anchor is on the passenger side but theres nothing on the drivers side unless its under the carpet.
- i also would like to know the best mounting location for harnesses w/o having a roll bar. but i believe having a roll bar is the safest solution.
norice
Apr 26, 2002 09:01 PM
