need help asap.
Old Mar 7, 2007 | 06:57 PM
SICKBLKEK's Avatar
Default need help asap.
whats good honda-tech...im havin a problem i got a singal non vtec and i started the car and it stalled out on me and shut off...i changed the fuel filter and the fuel pump...i changed the spark plugs..and that the only thing ive done..any body else have an idea of what can be wrong with it...???
all feed back welcome....
Old Mar 7, 2007 | 07:01 PM
-JSpecEk*9-'s Avatar
Default Re: need help asap. (SICKBLKEK)
can you speak english?
Old Mar 7, 2007 | 07:06 PM
jayjayek's Avatar
New User
Default Re: need help asap. (-JdmEk*9-)
yea speak to me i can hear u.write u dumb nikka.
Old Mar 7, 2007 | 08:21 PM
Lmgrcivic's Avatar
you need to give more info whats done to the car what motor you have. Also learn to type better so people can help you
Old Mar 8, 2007 | 06:30 PM
SICKBLKEK's Avatar
i got a singal cam non vtec..in a ek..and the **** starts up but does not stay on...
Old Mar 8, 2007 | 06:39 PM
pdiggitydogg's Avatar
I know the school systems in NY arent that bad...
"S-I-N-G-L-E"
Are you throwing any cel's (check engine lights)?
Are your battery and alternator connections good/tight?
Does it stay running if you feather the throttle?
Is the air filter clean?
There could be a **** ton of things wrong...no one can diagnose the problem based on "the **** starts but does not stay on"
Old Mar 9, 2007 | 04:39 PM
SICKBLKEK's Avatar
Default Re: need help asap. (Lmgrcivic)
got alot of tuff *****s on this site talkin reckless...
Old Mar 9, 2007 | 05:37 PM
rsf-g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SICKBLKEK &raquo;</TD></TR><TR><TD CLASS="quote">got alot of tuff *****s on this site talkin reckless...</TD></TR></TABLE>
not the right place for this kind of language.
Old Mar 9, 2007 | 05:56 PM
96hatchy's Avatar
Default Re: need help asap. (rsf-g)
this is a place to learn about cars not threaten people because ur typing mistake. besides they're just messing around. chill out.
Old Mar 9, 2007 | 06:09 PM
SICKBLKEK's Avatar
THE CEL LIGHT IS ON AND THESE ARE THE CODES I GOT THE O2 SENSORS THE SPEED SENSOR...THE ATMOPHRIC SENSOR..
Old Mar 9, 2007 | 06:14 PM
TANGO28's Avatar
maybe ur idle is too low........................................
Old Mar 9, 2007 | 06:18 PM
SICKBLKEK's Avatar
Default Re: need help asap. (EG28)
YEAH IVE BEEN GETTIN THAT ANSWER BUT THE THING IS THAT I CAN REV IT AND IT STILL SHUT OFF..
Old Mar 9, 2007 | 06:59 PM
hatchi's Avatar
Timing might be off. did you check all the fuses?? Turn off your Caps button
Old Mar 9, 2007 | 07:25 PM
94hondacivicvtec's Avatar
Default Re: need help asap. (hatchi)
when you start it hold the petal to the floor if it starts to redline real quick then the timings good. if its good then check fuel system, air intake, or see if your cat is clooged (very very unlikely). if it doesnt start to redline and it gets up to 4000rpm or less then theres something in your ignition thats making it run on 3-2 cylinders. if this happends then check dist. spark plug wires- make sure there all in and pushed down tight, and plugs all or one of them could be way way off. that happend to my buddy's car
Old Mar 9, 2007 | 11:37 PM
SICKBLKEK's Avatar
Default Re: need help asap. (94hondacivicvtec)
thanks ima try and change the spark plug wires and see..thamks on the feedback
Old Mar 9, 2007 | 11:51 PM
sol2hatch's Avatar
OMG, that is the funniest **** I have seen in awhile. dont get butt hurt, its just the 1NTRAW3B yo, everyone is "tuff" round here, ya hear?
iamthefollower
10
Jul 28, 2011 09:19 PM
viciousvisionslarry
Apr 3, 2011 02:13 PM
dizzy16z6
Honda Civic (2006 - 2015)
Jan 2, 2008 10:58 AM
WolfGod
12
Jan 21, 2006 03:58 AM
vteckiller
Oct 9, 2002 04:24 PM
