where is my air intake temp. sensor.
ok during this whole winter i idle at about 1.8 - 2.1 grand. when cold. this goes is only during the winter. when its warm out my car idles fine. the car runs good and all but its just the idle. and i have a feeling that it could be my air temp sensor but i dont know where it is located for me to clean it. you think if i clean it my problem will be solved? when the water temp is normal (around 150) that is when i get normal idle. but before that idles high. and i know the cold weather is effecting something. so can someone post a pic of where those sensor or sensors are located? i got a 94 gsr with obd2 harness and obd1 ecu. and yes it is a swap. anyone heard of this problem? i know there could be like 30 reasons y i get high idle but everything seems fine when the weather is warm. and when its hot it even drops lower than normal idle.
thanks
thanks
i have the same exact sensor on my intake tube that is not used because i have it on my mani. so if i change them how long will it take for my ecu to understand that this sensor is good. will the action be right away or i have to drive around for a few for the ecu to understand
