Vac Digram For z6
Old Mar 7, 2007 | 03:05 PM
Hella_Fresh's Avatar
Default Vac Digram For z6
i need this cause my car keeps jumping from 1k -4k and keeps doing this over and over.
But when i unplug the IAT sensor, it will only go from 1k-2.5k
Old Mar 7, 2007 | 05:17 PM
Default Re: Vac Digram For z6 (sXekid)
ok update.. doesnt smoke anymore. had the two plugs in the back switched..
now it just jumps from 4k to 1k and over and over.
Old Mar 7, 2007 | 08:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sXekid &raquo;</TD></TR><TR><TD CLASS="quote">ok update.. doesnt smoke anymore. had the two plugs in the back switched..
now it just jumps from 4k to 1k and over and over.</TD></TR></TABLE>
Old Mar 7, 2007 | 08:37 PM
Got_soy's Avatar
coolant level good?
also
i thinnk the map sensor plug can be swithched with another sensor plug
Old Mar 7, 2007 | 08:44 PM
Default Re: Vac Digram For z6 (Got_soy)
my map sensor is still on the wire wall
Old Mar 7, 2007 | 08:47 PM
Got_soy's Avatar
i was thinking that the ait and map were switched, unless they wont fit atall
NO codes im assuming
Old Mar 7, 2007 | 09:05 PM
no theres is codes. theres one for the IAT and Eletrical Load
Old Mar 7, 2007 | 09:07 PM
Got_soy's Avatar
check for bubbles in coolant, happend to me once. Good luck with the car
Old Mar 7, 2007 | 09:08 PM
what would that do with the reving from 4k to 1k over and over?
Old Mar 7, 2007 | 09:11 PM
Iron_Forrix's Avatar
bad IACV? thats a common issue with the surging idle.
I replaced mine and the surging stopped.
Old Mar 8, 2007 | 11:17 AM
175Shot4Door's Avatar
Default Re: (Iron_Forrix)
you have the same proboly as me man i still have mine on the firewall i am bounching from 1 to 2500 i cant figure it out eather as soon as u do man plz tell me
Old Mar 8, 2007 | 01:35 PM
Default Re: (175Shot4Door)
yea i fixed it. now it onlg goes from like 1800 to 1k
Old Mar 8, 2007 | 08:54 PM
Default Re: (sXekid)
how did u fix it ?? man can u plz take a pic of the motor and vacum lines so i can see whats wrong with mine
Old Mar 8, 2007 | 10:31 PM
black88si's Avatar
Old Mar 9, 2007 | 10:33 AM
Default Re: (black88si)
so are u saying i dont have to run any lines into the silinoids ? just one line to the map ?
ATegra91 Da
Mar 29, 2017 07:00 AM
the.hamburglar
Sep 2, 2006 02:36 PM
spidermancivic
May 27, 2005 10:19 AM
FourthGenHatch
May 19, 2003 10:51 AM
