(Bitch pin?) replacement Pleaseeeee help
Hows it going party people. I just SUCCESSFULLY got done doing a mini me swap on my 1997 civic, its a d15b7 with an d16z6 del sol head...its pretty sweet. I love it!!! Well doing this swap i came into a couple problems that left me with a couple retarded loose ends to fix. One problem i had was while taking the Dowel pin (which connects the tranny to the shift linkage) is ******* mia. I am currently using a bolt and a nut and i believe it is a little skinner than the dowel pin, which leaves me with a huge difference in shifting, i can literally wiggle the shifter back and forth...in gear...
!!! ahhh confusing!!! Pleaseee help me. does anyone have a suggesting on what i can possibly use to replace the pin and drive in comfort? Possibly a particular size bolt and nut? Possibly the size dowel pin that came on it? Or maybe even an suggestion on where i can get another pin cheap. Please respond, any suggestions are very appreciated. Thank you so much!!! Please help mee!!!!
I had to special order because my dealership didn't carry or have any on stock so I ordered I think 6 of them.
I got about 3 or 4 left because I gave somebody one when I sold the shift linkage. But I have an EF, EG and about to have a DB8 so I will use them.
Don't be stupid and just get them from the stealership.
Yep go to honda and tell them you need a shift linkage pin. If he is any good he should be able to locate it.
http://www.slhondaparts.com
streetracerof06
Oct 27, 2005 09:20 AM
USDM 4G VTEC
13
Nov 30, 2002 08:30 PM
