very important vtec qusetion!!!!!!!!!!!!!!!!!!!!
i wire my vtec solined right but the vtec oil pressure switch i wired the postive right but tthe ground i put the ground wire on the tranny ground but i dont fell vtec kick in . what could be the problem but i dont have any codes either. someone help me!!!!!!!!!!
need more info...what kind of motor on a SOHC vtec you don't really feel vtec kick in.....what ecu are you running
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efking1985 »</TD></TR><TR><TD CLASS="quote">im running sohc and running stock p28 but i dont feel power at 6500 .</TD></TR></TABLE>
Your not gonna feel vtec on a SOHC. You may be able to barely hear it but its not gonna break loose the tires when it hits.
heres what you do... on your ecu i thing the wires should be grey and purple( not sure cause i have a p08 ) but take the to wires and run a volt meter to each one, one at a time rev your engine till vtech is supposed to hit and if the volt meter jumps to an over load then that is the wire that goes to you solinoid and the other is to the vtech oil pressure sensor if it doesnt work after that than your **** out of luck
vtech solinoid goes to ecu
and the pressure sensor is grounded out in the ecu
good luck and let me know how it does
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SD_Lurker »</TD></TR><TR><TD CLASS="quote">
Your not gonna feel vtec on a SOHC. You may be able to barely hear it but its not gonna break loose the tires when it hits. </TD></TR></TABLE>
that is wrong cause you can hear it and feel it.. ive seen and have been in sohc vtechs in a ef si hatch that have beaten and atlest kept up with most b16s
but i changed my obdo to obd1 from rywire and it said to wire the vtec oil pressure switch black wire to a ground witch i did and i put it on the tranny ground could it still work.
i have only felt and heard vtec on two SOHCs ever in my life.
one was my homies EF hatch with a jdm D15b and the other happened last night when i test drove a 95 civic ex coupe owned by a 50 year old guy with a cheapy short ram.
felt and heard vtec. weird.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efking1985 »</TD></TR><TR><TD CLASS="quote">but i changed my obdo to obd1 from rywire and it said to wire the vtec oil pressure switch black wire to a ground witch i did and i put it on the tranny ground could it still work.</TD></TR></TABLE>
im not sure if it would still work... just ground it to the wire its supposed to use on the ecu like i said. its only 2 wires its not hard at all i wired mine up on my first try... hondas too easy
LOL, open TB on my brothers stock 97 4door EX with the stock y8 you can sure as hell hear VTEC engage, fun times. I like y8 IM's, they do wonders for SOHC's.
blackccoupe
81
Nov 20, 2003 02:07 PM
