weird noise during 3.5krpm
my 95 gsr makes this weird rattle noise during 3.5k-3.8k rpm, only in those rpm it makes this rattling noise, anyone have a similar problem or a solution? This all happened after i changed my exhaust back to stock setup.
Modified by lspecz at 3:02 PM 3/7/2007
Check the tin shields over your exhaust - from cat converter (if installed) back - at certain resonance levels these can vibrate enough to touch exhaust (hence rattling noise) if not installed properly or bent.
these can be bent back outwards, or removed relatively easily.
Tho don't start work on it if you have just been for a drive. it hurts.
