valve cover gromits. lost one
Old Mar 7, 2007 | 01:16 PM
o0Jash0o's Avatar
Default valve cover gromits. lost one
i lost a gromit while changing the valve cover gasket. they`ll take 4 days to order a set of 7 for 27.95
is there some way i can substitute the gromit with say metal washers and a rubber washer and use it in the middle valve cover bolt?
also can i just pull one off any hoda they look to be all the same size but im not sure and the junk yard close before i get off work
Old Mar 7, 2007 | 03:51 PM
sauceja's Avatar
Default Re: valve cover gromits. lost one (o0Jash0o)
for 30.00 you can get a whole new valve cover gasket set.
But yeah I would say to get you by you could use a grommet from just about any honda.
If you do that you will want to replace them as soon as possible with the right ones.
Old Mar 7, 2007 | 06:00 PM
TB123's Avatar
I lost one once and I looked at all of the departmant stores around town and could not find one that fit. I ended up needing to buy one from Honda. You don't need to get a whole new set. I ordered one from honda and it was only like 3 dollars.
Old Mar 7, 2007 | 06:45 PM
JmurGSR98's Avatar
Default Re: valve cover gromits. lost one (TB123)
3 dollars? I had to pay $6 for one at the dealership. Acurapartswarehouse.com has them for either $2.95 or $3.95
Old Mar 8, 2007 | 11:57 AM
o0Jash0o's Avatar
Default Re: valve cover gromits. lost one (JmurGSR98)
got off early from work and went to the junkyard and saw the first da ide seen in a parts lot in a year or so. valve cover, intake manifold, exhaust manifold, valves, springs most everything gone stripped....but i found three of the gromits on the ground laying ontop of the hood. cleaned them up and good to go. didnt cost me but a dollar.
Old Mar 8, 2007 | 12:59 PM
sauceja's Avatar
A dollar **** you should have just stuck those in your pocket but still not bad.
Old Mar 8, 2007 | 04:14 PM
o0Jash0o's Avatar
Default Re: valve cover gromits. lost one (sauceja)
well it cost a dollar to get it lol
EG-SIXV-TEC
Nov 10, 2009 09:47 AM
webbs2jzgte
Mar 10, 2009 09:32 PM
Nicks95GSR
Jun 2, 2008 03:24 AM
B2FiNiTY
Aug 18, 2003 06:45 PM
nerdish
May 1, 2002 11:48 AM
